4X4 arb +
This is a discussion on 4X4 arb + within the Awesome GTI forums, part of the BRISKODA Partners category; Hi Sarah am looking at replacing the front & rear ARB's on my Octy 4X4 2001 In a couple of ...
Go Back   BRISKODA - The Skoda Forums > BRISKODA Partners > Awesome GTI
Old 20-02-2008, 07:10   #1
Go 4X4 it
FOZ1's Avatar
Question 4X4 arb +
Hi Sarah am looking at replacing the front & rear ARB's on my Octy 4X4 2001 In a couple of months.
I have done some searching & think the following sound good:-
Neuspeed Rear Race Anti-Roll Bar R32/TT 4wd 25mm (SU-ARB-NEU-R32B)
Neuspeed Front Anti-Roll Bar TT/LCR/VRS 22mm (SU-ARB-NEU-TTA)
(I have also seen a PI spring kit that gives a 30mm drop.
pardon my ignorance, but would these fit with current shockers & Could you fit these if I got them?)
What would be the cost for all of this ?
How long would it take to do?(ie could I come over & wait or would it be a couple of days?)
How much notice would you need to book it in?
Thanks in advance
Fred.
Out of the asylum.- Into Freedom
Previous:-Red Citroen ZX Volcane, Chipped, Black Diamond drilled & grooved front discs, Greenstuff pads, Green Induction Kit, 16" Alloys.Powerflow exhaust.
Black Alfa 146 Ti. Standard (nearly enough) Red Alfa 156 sportwagon 1.6 (not enough)
FOZ1 is offline
Old 20-02-2008, 11:28   #2
Site Sponsor
AwesomeSarah's Avatar
Default Re: 4X4 arb +
Hi Fred
One thing that made me Ooooh is the PI springs.....sorry not my fav spring
They tend to be cut down springs and I dont think they get a good rave on any car , am sorry
The main problem with lowering on springs alone , is the fact that it is the shockers that wear and if you put just lowering springs on then they will wear alot quicker
I usually say approx 40-60k miles the shockers are well...shocked
The front ARB is £145 + VAT and the rear ARB is £245 + VAT
Labour on the front arb is £99 + VAT and then you would need a geo set up afterwards , but if you have springs fitted at the same time the price includes the geo so would not be needed
(So in the long run it will save you to do both jobs together)
The rear one is £49.50 + VAT for fitting
Fitting of springs , sockers or springs and shockers is £167.50 + VAT , so it does work out cheaper to do everything at the same time , if you can
I am sorry I can help you spend your money)
I would say that a possible good move could be the H&R springs as these are specific to your car will lower 40mm and are £150 + VAT
The ARB`s and suspension would possibly be approx 6 to 7 hours
You can wait not a problem we have a lovely warm waiting room with TV etc or we can get you a courtesy car as it is such a long job and you can then go to the Trafford centre
We would be looking at approx 2 to 3 weeks too
I hope that helps?
Sarah
AwesomeSarah is offline
Old 20-02-2008, 11:29   #3
Site Sponsor
Blimey , dont I go on
Sarah
Old 20-02-2008, 16:21   #4
Go 4X4 it
FOZ1's Avatar
Right, after reading all the info you have so kindly given me, I would like to pick your brains a bit more, as to what would have the greater effect,
both arb's only, H&R spring kit only, or rear arb + H&R spring kit.
As having done the maths, I now need to lie down
Would be looking to have the work done around the middle of April.
hope you don't mind me going on a bit but really want to get this right.
Thanks again
Fred.
PS Your ability to spend money has been mentioned a few times :
FOZ1 is offline
Old 20-02-2008, 19:26   #5
splash!!!!
bengie's Avatar
the rear ARB won't fit without some, er, modification to the spare wheel well
owner of a skoda octavia 4xvrs3
bengie is offline
Old 21-02-2008, 06:58   #6
Go 4X4 it
FOZ1's Avatar
Yeah,read that in another thread, although Sarah did say it wasn't that drastic.
Will have to see just how much "redesigning" is req.
I assume the spare wheel will still fit
FOZ1 is offline
Old 21-02-2008, 10:56   #7
EddyH's Avatar
Assuming the ARB you're going for is the same design as the standard R32 then the modification required is fairly tame and takes seconds to do. Also the spare wheel does still fit.
EddyH
Audi S8
Audi A3 2.0 TDI Sport
EddyH is offline
The Following User Says Thank You to EddyH For This Useful Post:
FOZ1 (21-02-2008)
Old 21-02-2008, 12:28   #8
Site Sponsor
Hi
Yes it is not too bad , and as Eddie said the wheel does still fit
I hope that helps?
Hope your good Eddie?
Sarah
Old 21-02-2008, 15:11   #9
Go 4X4 it
FOZ1's Avatar
Hi sarah,
not sure if you have seen post 4 ?
apologies if you are stil working things out
FOZ1 is offline
Old 21-02-2008, 15:39   #10
Site Sponsor
Ooops
Teach me to read threads properly
I would say rear arb + H&R spring kit
But wait for others to say otherwise....
I would have thought that combo
The rear ARB is fantastic too , I do think at times it is good to do 1 thing or these 2 before spending more , as then you can see what benifits you get with each part
Sarah
Old 21-02-2008, 17:01   #11
Go 4X4 it
FOZ1's Avatar
Originally Posted by AwesomeSarah View Post
Ooops
Sarah
Excellent, I will have to sort out the finances, & book a date, thanks so much for your help, I will be in touch nearer the time
Cheers Sarah
Fred.
FOZ1 is offline
Old 21-02-2008, 17:05   #12
Site Sponsor
Hi Fred
No worries my dear
Just wait for others to come on though and say different , but that is my opinion
Have fun , look behind the sofa too you never know
Sarah
Old 21-02-2008, 19:56   #13
Go 4X4 it
FOZ1's Avatar
Hi Fred
No worries my dear
Sarah
I just looked behind the sofa,..............
found two kids searching for money, 6 coco pops, 2 buttons & a ball of fluff
As for the others, they quite rightly have their opinions, which are always worth reading(thats how we learn), but I asked you for yours, as you also have experiance in this field.
It would be churlish to to pass over it for someone else's who I don't really know.
Also you are much better looking than them, which is the clincher.
Thanks
Fred
FOZ1 is offline
Old 21-02-2008, 20:01   #14
Go 4X4 it
FOZ1's Avatar
Does all this creeping get me any discount ?
FOZ1 is offline
Old 22-02-2008, 09:44   #15
Site Sponsor
Hi Fred
It gets you 2 "Awesome" brews
But keep it coming , I like it
Sarah
Old 22-02-2008, 15:30   #16
Go 4X4 it
FOZ1's Avatar
Oooooh 2 brews , must try harder & go for a biscuit or two.
FOZ1 is offline
Old 23-02-2008, 12:32   #17
Site Sponsor
We dont ever have buscuits but I will make an exception for you
Sarah
Old 23-02-2008, 18:27   #18
Go 4X4 it
FOZ1's Avatar
Sarah
Why thankyou
FOZ1 is offline
