Airbag Fault-00588
This is a discussion on Airbag Fault-00588 within the Diagnostics & VAG-COM forums, part of the General Motoring Discussions category; My first post, so not sure if it's in the right forum. Car: 54 Octavia 1.9TDi 105PD After having a ...
Old 23-05-2008, 11:05   #1
Default Airbag Fault-00588
After having a near miss, hard breaking and the obvious horn bashing my dreaded airbag warning light came on.
I've had it scanned with a VAG305 (any good?) by a friend at work, and it gave me this error:
0588 - Airbag Igniter; Driver Side (N95): Resistance too Low
00588 - Airbag Igniter; Driver Side (N95): Resistance too High
Possible Symptoms
  • Airbag Warning Light active
Possible Causes
  • Wiring from/to Airbag Igniter Driver Side (N95) faulty
  • Coil Spring with Slip Ring (F138) faulty
  • Airbag Igniter Driver Side (N95) faulty
Possible Solutions
  • Check Wiring from/to Airbag Igniter Driver Side (N95)
  • Check Coil Spring with Slip Ring (F138)
  • Check Airbag Igniter Driver Side (N95)
After doing a reset it went off for a few seconds then came back on, indicating a real fault i'm guessing.
My question is how can it be fixed. Could I try myself or should I take it in to a dealer and be prepared to get ripped off, I mean pay a inflated price.
Any help much appreciated.
jamesy247 is offline
Old 23-05-2008, 14:51   #2
Briskoda Staff
VRStu's Avatar
Default Re: Airbag Fault-00588
If it was the connector under the seat (which it probably is) then Skoda issued a fix for it so I'd like to think you could get it fixed without being charged.
Stu - Freedom Pimp
Stu's Car - 2007 Octavia vRS, Race Blue, Xenons, Columbus Navigation, Rear Parking Sensors, Maxi Dot, Light Assist, Jumbo Box, 18" Alloys, Stu's Cruise Control & OEM Integrated Bluetooth Telephone.
Something for Weekend - 2002 Lotus Elise RaceTech, Gunmetal, Radio, Carpet Mats.
VRStu is offline
Old 25-05-2008, 19:02   #3
Theresias's Avatar
Note #1: The driver airbag is the one in the steering wheel - not related to connectors under the seat at all.
Note #2: Fixing this would mean double checking the connectors and connections according to the factory repair manual with appropriate airbag testing tools.
Note #3: When copying information from out WIKI we would appreciate if you at least mention the source, even more we would like to see that you just place a link to the site since it's content is subject to change and copied information tends to outdate quite fast that way.
00588 - Ross-Tech Wiki
Note #4: We have seen these hand held scanners suppressing certain codes, they are also questionable in terms of the airbag control module issues - the same problems older versions of VAG-COM in combination with 3rd party hardware had.
Ross-Tech: VAG-COM: VW Issues
Sebastian
Theresias is offline
