This is a discussion on Code 17544 - Vacuum Hose question within the Diagnostics & VAG-COM forums, part of the General Motoring Discussions category; On my MK1 Octy VRS VAC-COM is showing fault code 17544 - Fuel Trim Bank. I have found that one ...
| Briskodian Join Date: Jan 2003 Location: West Sussex
| On my MK1 Octy VRS VAC-COM is showing fault code 17544 - Fuel Trim Bank. I have found that one of my vacuum hose is split. Is the one that comes off the inlet manifold at the gearbox end and does a 90 deg bend under the bracket to the right of the dip stick. I called skoda and they said I need part number 06A 145 691 AR (set of vacume pipes) at £48.89 + VAT !!! Aparently you cannot just buy the small rubber pipe as it is not a separate piece. Is this true - or have they quoted me the wrong part?
__________________ Steve _______________________________________ |
| Managed to have a good look today. The small pipe is held on by two clips. Replaced pipe - total cost £0.00!! Up yours Skoda ![]()
