This is a discussion on coolant temp sensor within the Diagnostics & VAG-COM forums, part of the General Motoring Discussions category; hi again i got this coming up as a intermittant fault would it be cos the engine wasnt running...
| Site Sponsor | Re: coolant temp sensor No I would say it is because it is on its way out. Intermittent means it does not happen all the time. But at around £20.00 + VAT it is worth replacing it Sarah |
| Why So Serious Join Date: Jan 2006 Location: "What" ...What ain't no god damn country
Members Car: a car Thanks: 287
| Re: coolant temp sensor just got in the car to come home engine warmed to about 70 degrees i looked down again and the temp gauge was all the way back to nothing looked again then it was back up to 90 is this what it means by intermittant |
| Site Sponsor | Re: coolant temp sensor Yup Thats it. Means sometimes it will work sometimes it wont. But at least it is a cheap repair Sarah |
| Briskodian Join Date: Aug 2005 Location: Dublin
Members Car: Octavia 1.8t 4x4 Thanks: 1
| Re: coolant temp sensor It's also extremely easy to do. |
| Re: coolant temp sensor question is now is it safe to drive to gatwick from cardiff as i'm off to see mickey mouse friday morning i scanned again this morning and could not find the fault is this because it is intermittant ill try again later my cars not gonna blow because of this is it ? i need to get to gatwick to let the cockney spivs park my car i'm going to leave them a note about cold starts and low front spoilers (although if i do this they wil prbably pi55 in my petrol tank) |
| Briskodian | Re: coolant temp sensor My temp gauge does the same thing every now and again! Someone said it is easy to change, what is IT? I guess you mean the temp sender unit or something. Can you tell me where abouts it is, so that I can replace mine?
__________________ 'No more beer!' (unless it's GF) |
| Site Sponsor | Re: coolant temp sensor Hi It litrally takes mins to do. As long as it is cold. It is in the thermostat housing Just unclip the plug. Take out the retaining clip. Replace with new one making sure seal ok Replace clip. Reconnect electrics and away you go. Sounds easy? Sarah |
| | #10 | |
| Partner Join Date: Sep 2003 Location: Newport Pagnell
Members Car: Mk2 Golf GTi 16v and building a 20VT MK2. Images: 2 Thanks: 29
| Re: coolant temp sensor Quote:
All sillyness aside yes you can, it 'may' use a bit more fuel thats all. | |
| | #12 |
| Re: coolant temp sensor For sure. A piece of free advice, stump up the extra £10 and put a whole thermostat housing on it, they are also common to break and it comes with the sensor anyhow. |
| | #14 |
| Briskodian | Re: coolant temp sensor OK I know its asking a lot, but do you have a part number? Oh.. I have a 2001 TDI 110. Thanks
| | #15 | |
It wil lbe different on the Octavia to the Fabia. | |
| | #16 |
| Briskodian | Re: coolant temp sensor Different? As in the part number , or the whole temp sensor / housing configuration? ![]()
| | #17 |
| Re: coolant temp sensor Both |
| | #18 |
| Briskodian | Re: coolant temp sensor God your quick with your replies If only all Skoda employee's were as quick! But as you are 'moving on' I'm not sure if you are a Skoda employee or not, any more!? Anyway, how do I fix my dodgy temperature thingy? Please... ![]()
| | #19 |
| Re: coolant temp sensor Im not a Skoda employee, never have been ![]() But I suspect you need a coolant temp switch.. There have been a few supersessions on it though, you will need the latest four pin green sensor. You local VAG dealer will have one, about £25 max inc VAT id say. |
| | #20 |
| Briskodian | Re: coolant temp sensor Thanks. So what are you doing on here? and how come you know soooooooo much?
| | #21 |
| Re: coolant temp sensor I work for a Skoda dealer I have owned a modded a fair few Skodas and wear Skoda underpants. That enough for ya? |
| | #22 |
Members Car: 4x4 turbo estate Thanks: 18
| Re: coolant temp sensor you should name your daughter to be fabia
