40,612 Members 1,518,134 Posts
Correcting your MPG display via VAG COM
This is a discussion on Correcting your MPG display via VAG COM within the Diagnostics & VAG-COM forums, part of the General Motoring Discussions category; Stolen from another forum. A member has just changed a setting using his VAG COM to correct the 10% difference ...
Old 25-02-2008, 20:14   #1
mluton's Avatar
Stolen from another forum. A member has just changed a setting using his VAG COM to correct the 10% difference in True MPG and displayed MPG.
Not sure what cars this will work on though.
VAG COM Change
17 - Instruments - Adaption-10 - Ch No. 3 - Original value 100 (this is a %) my new value is 110. Use TEST and see Average MPG drop in DIS!
Thread here:
A how-to with some VAG-COM modules - VWAUDI Forum
Red Skoda Octavia V//RS
mluton is offline
The Following 6 Users Say Thank You to mluton For This Useful Post:
Basil (25-02-2008), digitaldwarf (26-02-2008), ethos (26-02-2008), VRSPhil (25-02-2008), Wardy (26-02-2008), WW_VRS (25-02-2008)
Old 26-02-2008, 10:52   #2
ethos's Avatar
Members Car:
Re: Correcting your MPG display via VAG COM
I'd rather it lied to me I think
Octy vRS mk1; APR Stage 1, Forge 007p DV, THS TIP, Honda s2000 aerial, seat cupra front splitter, MAS alloy center caps, alpine CDE-9871R, infinity 6010cs, Jbl 75.4 and 10" sub.
Pug 205 gti; mi16 200bhp/tonne
ethos is offline
Old 26-02-2008, 14:28   #3
DGW
BRISKODA Staff
DGW's Avatar
That channel (ie 03) is not available on the 2007 Fabia vRS. This is a pity since on my car's first brim to brim tankful Trip 2 shows 54.0 mpg compared with my calculated figure of 43.57 mpg based on miles driven and fuel used.
But I did take the opportunity to use VAG-COM to increase power steering weight from 2 to 3 - and what a difference that makes.
Denis
2007 Fabia vRS - CC, ESP and full leather trim by Seat Surgeons ...48.12mpg...
DGW is offline
Old 26-02-2008, 19:30   #4
2.0 FSI Sport.
smstext's Avatar
Members Car: Octavia Mk2 FSI Sport
is this for all maxidots or just octys?
smstext is offline
Old 26-02-2008, 19:35   #5
roo
Ding, dong
roo's Avatar
Images: 4
It would be for all Octys that shows mpg on the display.
Jeff: Ambitious, but rubbish
Originally Posted by topgear.com
The police use the Octavia Vrs because they don’t look fast enough to catch a cold. That’s cheating
roo is offline
Old 26-02-2008, 19:44   #6
Broken :(
Wardy's Avatar
Members Car: Skoda Fabia vRS
Yeah, remember seeing this on TDIClub IIRC. Referred to as the 'fudge' factor
Steve
Wardy's Fabia vRS
xenons : sunroof : cruise : OEM+
"Racing is life. Anything before or after is just waiting." - Steve McQueen
"If in doubt, flat out." - Colin McRae
Wardy is offline
Old 27-02-2008, 03:50   #7
Uwe@Ross-Tech's Avatar
Members Car:
Some instrument clusters support this, and some don't.
54 show vs 43.5 actual is a 24% difference. Normally the maximum allowable tweak is 15%.
DGW: What's done to your car? Remap? Different FPR? Different fuel injectors? Being off 23% is a LOT.
-Uwe-
Uwe@Ross-Tech is offline
Old 08-03-2008, 18:08   #8
DGW
BRISKODA Staff
DGW's Avatar
-Uwe-
The engine is unmodified, Uwe. After 680 miles Trip 2 reads 56.3 mpg whereas calculated (actual) mpg is 46.44. I will continue logging fuel and mileage to see if mpg changes for the better.
Denis
DGW is offline
Old 08-03-2008, 23:44   #9
Members Car:
Still 21% off. How about a really kudgy solution: Set your car up to believe it's a US market car. Our gallons are about 20% smaller than yours. ;-)
Seriously though, ~45 imperial mpg seems awfully low for a Fabia with a TDI motor -- unless of course you have a serious case of lead-foot.
-Uwe-
Old 25-03-2008, 15:09   #10
'Little' John's Avatar
Members Car: Skoda Fabia vRS SE
-Uwe-
It depends on the sort of driving you are doing. It's about what I get doing my 8 mile commute to work. On a long run it's usually a bit better. My trip computer also normally reads about 10mpg too high!
'Little' John is offline
Old 25-03-2008, 15:35   #11
skudmissile's Avatar
Members Car:
-Uwe-
If i get 45mpg average i am doing well.
My average atm is 35mpg The Car needs mapping for the hybrid.
Run out of CASH
skudmissile is offline
Old 09-04-2008, 19:42   #12
octywagon's Avatar
Just tried to do this on my 2001 octy tdi and can't do it as there is no channel 3 to modify - oh well - was looking forward to correcting my display as it is also 10% out.
Eucalyptus 01 Octy Elegance TDI Wagon ~ ~ Honda 'stubby' aerial ~ Aero rear wiper
octywagon is offline
Old 13-04-2008, 15:55   #13
sibart's Avatar
Octy mk2 seems to be spot on, i do same route everyday and have done real life calculations, maxidot was within 0.1 mpg.
Car: Factory freebies, JKM Performance K04 Turbo Upgrade, JKM Performance BIG Brake Upgrade, Koni / Eibach Suspension, Eibach ARB's, Revo Map, KMD fuel pump, Columbus toy+ BT Kit(cheers Stu) ,light assist, maxidot,rear park sensors,cruise control.
sibart is offline
Similar Threads
Haywire MPG display Bizzy Fabia I 6 18-08-2007 19:34
Correcting the steering. mluton Octavia I 15 01-05-2007 13:13
VAG-COM: Octavia Climatronic display ColinD Technical Guides 6 08-04-2006 10:40
Display car info on climate display? logiclee Octavia I 12 28-10-2004 18:08
