This is a discussion on Dash lights within the Diagnostics & VAG-COM forums, part of the General Motoring Discussions category; Does anyone know if it is possible to disable the low windscreen washer light/beep, brake pad warning light and the ...
| Old Skool Fan Join Date: Jan 2004 Location: Bucks
Members Car: The First Skoda Fabia vRS Estate Images: 14 Thanks: 0
| Dash lights Does anyone know if it is possible to disable the low windscreen washer light/beep, brake pad warning light and the bulb gone warning lights on the Fabia vRS dash. I am currently fitting it in a non vrs without the above features. |
| Dash Lights Had a quick look, can you point me closer? Whats it under on the Vag Com website? |
| Partner Join Date: Sep 2003 Location: Newport Pagnell
Members Car: Mk2 Golf GTi 16v and building a 20VT MK2. Images: 2 Thanks: 29
| Yes it is, if you cant find the info im in work tomorrow and i'll look up the coding numbers for you. |
| Briskodian Join Date: Jun 2004 Location: West Yorkshire
Members Car: Audi A6 Thanks: 36
| Some info here assuming the fabia clocks use the same codes as most other VAG cars. Ross will be able to clarify for you tomorrow.
__________________ EddyH Audi A6 Avant 2.7 TDI Audi A3 2.0 TDI Sport |
| Dash Lights | TIMVRS | Styling and Car Care | 18 | 25-06-2005 11:00 |
| what colour are the dash board lights? | boyced | Octavia I | 9 | 17-08-2004 12:07 |
| Bright lights Bright lights | paxton | Fabia I | 16 | 15-08-2004 18:06 |
| Flashing Dash Lights? | intercrash | Maintenance & Performance | 4 | 04-02-2004 11:31 |
| warning lights on dash | speednut | Maintenance & Performance | 3 | 20-11-2003 14:07 |
