40,613 Members 1,518,176 Posts
Did some logs with VAG COM need help interpretating them
This is a discussion on Did some logs with VAG COM need help interpretating them within the Diagnostics & VAG-COM forums, part of the General Motoring Discussions category; OK as you might have seen I had a mystery engine light come on the other day. I scanned it ...
Old 30-08-2008, 12:54   #1
ultra_joel88's Avatar
Members Car: 04 Fabia vRS (180/300)
I scanned it with vag com and it came up with this
VAG-COM Version: Release 311.2-N
Control Module Part Number: 038 906 019 LA
Component and/or Version: 1,9l R4 EDC 0400SG 5405
Software Coding: 00102
Work Shop Code: WSC 13765
Additional Info: TMBWU46Y944076110 SKZ7Z0D2414884
1 Fault Found:
17678 - Pump-Jet Valve: Cylinder 4 (N243): Regulation Range Exceeded
P1270 - 35-10 - - - Intermittent
I did some logs today and got these
CAME OUT AS GIBBERISH PLEASE SEE BELOW
'04 Fabia VRS - P-Torque STG1, 312mm Brakes, Whiteline RARB, SEAT Sport Strut Brace, Pipercross Panel Filter & PD160 Intake, Pioneer and Infinity ICE, Custom exhaust system w/ de-cat, CCV Bypass w/ Catch Can, Swoosh Gauges, Window Tints
ultra_joel88 is offline
Old 30-08-2008, 12:56   #2
Re: Did some logs with VAG COM need help interpretating them
How do i copy these properly?
Old 30-08-2008, 13:03   #3
Right it all came out as gibberish.
I logged GROUP 13 on VAG COM at Idle.
And got this
Cyl 1 Cyl 2 Cyl 3 Cyl 4
-2.8 to +2.8 mg/H -2.8 to +2.8 mg/H -2.8 to +2.8 mg/H -2.8 to +2.8 mg/H
mg/R mg/R mg/R mg/R
-1.06 -1.69 -0.4 2.99
-1.08 -1.65 -0.42 2.99
-1.08 -1.62 -0.47 2.99
-1.08 -1.58 -0.52 2.99
-1.08 -1.53 -0.59 2.99
I also logged GROUP 11
And at idle Cylinders 1-3 read 0
But cylinder 4 reads 47
Does this mean I have an injector fault? Or is my tuning box playing havoc with them?
Old 30-08-2008, 13:08   #4
I'm also trying to work out why my Boost gauge is reading 22 psi when booting the car in 3rd or 4th gear - not spiking but holding at this value.
I logged GROUP 11 which I think its the right one
Engine speed Spec. intake press. Actual intake press. D.cycle MAP
2079 2136 1872 47.8
2247 2328 2316 58.6
2436 2340 2388 59.4
2646 2340 2376 62.2
2856 2340 2448 65.3
3066 2340 2400 65.7
3213 2340 2400 66.5
3402 2340 2376 66.9
3570 2340 2352 67.7
3696 2028 2268 64.9
3171 1044 1632 38.3
2772 2220 1656 31.1
2835 2268 2244 60.6
2940 2256 2304 65.3
3003 1920 2328 83.3
2541 1020 1464 38.6
1995 1176 1272 45.4
2394 1332 1236 47.8
2352 1380 1296 50.2
2394 1908 1452 41.8
2394 2136 2004 53
2457 2148 2244 59
2499 2148 2124 55.4
2541 2076 2196 59
2184 1008 1524 35.1
1596 996 1260 28.7
2058 996 1140 33.5
2058 996 1092 32.7
2037 996 1068 32.3
2016 996 1056 32.3
1995 996 1044 32.3
1995 996 1044 31.9
1932 996 1032 31.5
1659 996 1032 29.9
1134 996 1032 21.9
945 1032 1020 22.3
1890 996 996 28.3
3297 1044 984 38.6
3339 1392 1188 46.6
3381 2340 1908 57.8
3507 2340 2232 61
3633 2340 2316 64.5
3780 2340 2304 64.5
3885 2328 2292 64.5
3486 1056 1836 38.6
2835 1032 1500 38.6
2814 1020 1332 38.6
2793 1020 1284 38.6
2772 1020 1260 38.6
2730 1020 1248 38.6
2709 1020 1248 38.6
2688 1020 1236 38.6
2667 1020 1236 38.6
2646 1020 1224 38.6
2646 1020 1224 38.6
2625 1020 1212 38.6
2604 1020 1212 38.6
Old 30-08-2008, 13:15   #5
Also the car seems to run rough whilst the laptop is plugged in and running vag com is this normal?
Bit fed up with the car at the moment trying to get to the botom of it the bloody tuning box is at the route of it I bet.
Old 30-08-2008, 13:30   #6
roo
Ding, dong
roo's Avatar
Images: 4
1 Fault Found:
You've got it in one. All it is, is that the tuning box tells the PD injector that it needs more fuel than the injector can handle so up comes the fault code.
Remember a tuning box will never be as good as a proper remap as all it does is interrupt the information going between the injectors and the ECU and then increase the value so that more fuel is pumped into the cylinder.
Jeff: Ambitious, but rubbish
Originally Posted by topgear.com
The police use the Octavia Vrs because they don’t look fast enough to catch a cold. That’s cheating
roo is offline
Old 30-08-2008, 13:35   #7
So all its doing its overfuelling injector number 4?
**** that, I know the price of PD injectors.
Old 30-08-2008, 13:40   #8
roo
Ding, dong
roo's Avatar
Images: 4
the thing is that fault code could have been there for a while and be because you booted it in 2nd gear once a few weeks ago. clear it, drive notmally and see if it comes up again. There is nothing wrong with your pd injectors, it's just that the tuning box made the ecu ask for more fuel than it could reasonably handle.
I would not worry, but if you are, diconnect the tuning box for a week and see if it comes up again.
roo is offline
Old 30-08-2008, 13:49   #9
You were correct.
I just disconnected the box and checked the figures again.
This time at idle they read as follows:
mg/R mg/R mg/R mg/R
0 -0.19 0 0.14
0 -0.19 0.05 0.14
0 -0.21 0.07 0.16
-0.02 -0.26 0.07 0.19
0 -0.24 0.07 0.16
0 -0.26 0.07 0.16
0 -0.24 0.07 0.14
0 -0.24 0.07 0.16
-0.02 -0.24 0.07 0.16
-0.02 -0.24 0.09 0.16
0 -0.24 0.07 0.16
-0.05 -0.26 0.07 0.16
-0.02 -0.24 0.07 0.14
0 -0.21 0.07 0.14
-0.02 -0.19 0.07 0.09
No idea why the box was overfuelling injector 4 so much?
Old 30-08-2008, 13:53   #10
roo
Ding, dong
roo's Avatar
Images: 4
It's just one of those things. Maybe it's just that injector 4 is more sensitive?
roo is offline
Old 30-08-2008, 13:54   #11
Or maybe the tuning box is not set up right for the PD130.
I had another tuning box on for months, and never had a fault code even on the max setting. This had thrown up 2 in as many weeks
Old 30-08-2008, 14:38   #12
Txt Spk Police
VRStu's Avatar
Members Car: Audi S3
It could be a faulty tuning box.
Stu
VRStu is offline
Similar Threads
N75 vag-com logs what do you think? martziniuk Diagnostics & VAG-COM 16 12-12-2007 22:44
2008MY Octavia vRS TFSi Baseline VAG-COM Logs VRStu Reference Materials 0 26-11-2007 23:29
vagcom logs - low g/s? gorsey Octavia I 14 08-11-2006 13:04
VAG-COM logs - opinions required. Goochie Octavia I 8 19-03-2006 19:47
Custom Code Remap VAG-COM Logs Josh_PoloGTi Fabia I 4 12-09-2005 18:08
