This is a discussion on Disabling 'bulb out' warning? within the Diagnostics & VAG-COM forums, part of the General Motoring Discussions category; During the discussion of retrofit 'HID' light setups here it was mentioned that the ballast ignitor units only use one ...
| Broken :( Join Date: Oct 2004 Location: Around Manchester & Cheshire
Members Car: Skoda Fabia vRS Thanks: 473
| Disabling 'bulb out' warning? During the discussion of retrofit 'HID' light setups here it was mentioned that the ballast ignitor units only use one of the two headlight wires, the result of which being the bulb failure dash light is on all the time when using them. Is there a setting within VAG-COM to disable the warning? If so, could you tell me where it is? Many thanks, Steve
__________________ Wardy's Fabia vRS ![]() xenons : sunroof : cruise : OEM+ ![]() "Racing is life. Anything before or after is just waiting." - Steve McQueen "If in doubt, flat out." - Colin McRae |
