This is a discussion on Does Vagcom measure torque at the wheels? within the Diagnostics & VAG-COM forums, part of the General Motoring Discussions category; Yes? It's just I did some logs this evening whilst bored, and I couldn't get the torque to go much ...
Members Car: Skoda Fabia Mongrel Images: 5 Thanks: 79
| Does Vagcom measure torque at the wheels? Yes? It's just I did some logs this evening whilst bored, and I couldn't get the torque to go much above 400Nm. Most of the readouts were 390+, with one 404Nm. If this is at the wheels then I'm happy my usual 360lb/ft at the flywheel is still accurate. If its 404Nm at the engine, I need to be worried. ![]() With the yanks all liking to measure HP at the wheels, I figure this could be the issue here. Oh, and doing logs on vagcom is fun. ![]()
__________________ Jason - Only a Skoda. Custom Fabia Bonnet Lifter Kits - £45! Click Me. BRISKODA CLUBSTAND @ Castle Combe! 25/04/09! Track session too! Click me! See the mongrel's 260bhp Dyno Video! |
| Briskodian Join Date: Apr 2006 Location: Mid Germany
Members Car: MY 2007 Thanks: 1
| Re: Does Vagcom measure torque at the wheels? VAG-COM itself doesn't measure anything, it just tells you what your car "thinks". In general these torque values are less real and only for ECU internal calculation purposes. Of course these values do NOT represent the values at the wheels...
__________________ Sebastian |
| Fabian | Re: Does Vagcom measure torque at the wheels? |
| | #4 | |
| Briskodian | Re: Does Vagcom measure torque at the wheels? Quote:
![]() It calculates what the torque should be given the air/fuel in/mixture and some basic "heat engine" sums. | |
| Re: Does Vagcom measure torque at the wheels? In that case, I shall not be too fussed. Car feels as quick as ever, so not bothered.. Thanks for the PM Bryan.
| Briskodian | Re: Does Vagcom measure torque at the wheels? bit of a thick question, but how can i get my vag-com to do a log of bhp tourque and intake and engine temperature? is it something to do with vag-scope? cheers john
__________________ Run out of CASH |
| | #8 | |
Members Car: 2004 Fabia vRS TDI PD130 Thanks: 21
Block 7 measures Fuel temp, intake temp and coolent temp.
__________________ John His Slow Black Diesel Powered Hatchback Hers Full Fat HotHatch with Cup suspension and spolier kit | |
| Re: Does Vagcom measure torque at the wheels? Jason I've never had vag-com measure over 410nm. Think this is the limit.
| | #10 | |
-Uwe- | |
| | #11 | |
| | #12 | |
_________ john
__________________ Run out of CASH | |
| | #13 |
| Briskodian | Re: Does Vagcom measure torque at the wheels? right at 4347rpm vag-com shows 338nm of tourque, so by calculation does this equal 206bhp? cant be right cos all i have done is remapp. or is this engine bhp not wheel hp? thanks john
| | #14 | |
What remap you got?
| | #15 |
| Briskodian | Re: Does Vagcom measure torque at the wheels? my own re-mapp, used a flasher lead to read the map then emailed it off to a tuning company. 70 quid later i recieved the modded map back and i reloaded the map back onto the car. job done
| | #16 | |
Which company have you used if you dont mind me asking. PM me if you want.
| | #17 |
| Briskodian | Re: Does Vagcom measure torque at the wheels? A polish company by any chance? I've been having a play around with vag-com and kpower and was wondering if there is one measuing block that will give me rpm and speed? At the moment i've been logging blocks 06 and 20 but the timestamps are slightly out between the two blocks. I've done two runs so far which have both consistantly shown 221hp@4500rpm and 306lb/ft@ 3200rpm ![]() |
| | #18 |
| Re: Does Vagcom measure torque at the wheels? Nope its a Uk company he's used. But i know the polish one your thinking. May even be giving it a go this year. ![]()
