40,612 Members 1,518,136 Posts
Door Warning Dash Light
This is a discussion on Door Warning Dash Light within the Diagnostics & VAG-COM forums, part of the General Motoring Discussions category; Hi guys... I have a Skoda Fabia Hatch 1.4 16v, and I'm pretty sure it has the lights on the ...
Old 04-12-2007, 13:25   #1
Kookie_Monster's Avatar
Members Car:
Hi guys...
I have a Skoda Fabia Hatch 1.4 16v, and I'm pretty sure it has the lights on the dash indicating whether the doors are open our not, they're just not active.
What I wanna know is which code must be changed with VAG to activate it...
One other thing: I think the driver's door microswitch might be damaged, as the door only activates lights and all that once it's almost shut (at least it's not completely dead!! ). As soon as I open it a little more, it turns everything off, as if it was closed. Is there any way to correct this without changing the microswitch?
Thanks in advance!
Kookie_Monster is offline
Old 06-12-2007, 11:35   #2
Members Car:
Re: Door Warning Dash Light
No one?
Old 06-12-2007, 11:47   #3
Txt Spk Police
VRStu's Avatar
Members Car: Audi S3
Sorry I've not seen your post before - must have missed it.
Anyway - I would think if the car was fitted with the circuit it would be enabled. Just because you can see the symbol on the dash doesn't mean it's operational.
Difficult so say on the other question but the microswitch would be the first place to try I think.
Stu
VRStu is offline
Old 06-12-2007, 11:57   #4
Members Car:
Thanks for your answer!
About the symbol, one would think that if the car can detect the doors being open (by turning on the lights and so), could also light up the symbol on the dash? Right? or wrong? lol
Secondly, the microswitch thingy, as I said, it works when the door is almost closed (or barely open, whichever you prefer! lol). Searching the forum, I found someone (can't remember who) who had the same problem... but couldn't find the answer to it!
Old 06-12-2007, 12:20   #5
Txt Spk Police
VRStu's Avatar
Many of the dashpods are a bit generic and therefore not all of the symbols will work on all models.
An example - pre 2006MY Octavia II have a Cruise Control symbol on the dash but it doesn't illuminate because it wasn't ever programmed into the firmware. If you put a newer dashpod in one of these cars then most of the time the symbol will illuminate but in both cases the Cruise Control will work perfectly.
What I'm saying is that because your interior lights work it doesn't follow that the symbol will illuminate.
Stu
VRStu is offline
The Following User Says Thank You to VRStu For This Useful Post:
Kookie_Monster (06-12-2007)
Old 06-12-2007, 12:24   #6
Members Car:
Ok, got it!
Thanks!
Old 06-12-2007, 16:06   #7
Theresias's Avatar
Members Car: MY 2007
Stu already stated the obvious, but we could still look into it a little more detailed. What's your instrument cluster part number and current coding?
Sebastian
Theresias is offline
Old 06-12-2007, 21:45   #8
2.0 FSI Sport.
smstext's Avatar
Members Car: Octavia Mk2 FSI Sport
where is the door switch? i was looking for it the other day out of curiosity!!
smstext is offline
Old 06-12-2007, 21:56   #9
Jelly Mould
fordfan's Avatar
Members Car: Ford
It's a microswitch built into the catch on the door.
Kookie_Monster, you will only get a door open warning light on the Fabia Elegance
fordfan is offline
Old 07-12-2007, 15:17   #10
Members Car:
I don't have that info right now. I'll give it a look and report back when I can!
@fordfan: mine is the comfort version. Maybe that's why...
Old 09-12-2007, 10:27   #11
Members Car:
Here's the info from a Fabia 2001 1.4 Auto Comfort, does this help?
Sunday,07,October,2007,10:01:21:15738
VAG-COM Version: Release 704.1
Data version: 20070723
Chassis Type: 6Y - Skoda Fabia
Scan: 01 02 03 08 09 15 17 19 25 37 44 46 56 76
VIN: TMBNC46Y523398***
Address 01: Engine Labels: 036-906-034-APE.LBL
Part No: 036 906 034 AE
Component: MARELLI 4LV 3778
Coding: 00063
Shop #: WSC 13765
TMBNC46Y523398*** SKZ7Z0A1112509
No fault code found.
Readiness: 0000 0000
Address 02: Auto Trans Labels: None
Part No: 001 927 731 H
Component: AG4 Getriebe 001 2981
Address 08: Auto HVAC Labels: None
Part No: 6Y0 820 045
Component: Klimaanlage X0770
Address 09: Cent. Elect. Labels: None
Part No: 6Q0 937 049 B
Component: BORDNETZ-SG. 1S31
Coding: 25754
Shop #: WSC 13765
1 Fault Found:
00966 - Fuse for Blinkers (S151)
37-00 - Faulty
Address 15: Airbags Labels: 6Q0-909-605-VW5.LBL
Part No: 1C0 909 601 C
Component: 02 AIRBAG VW51 02
Coding: 12338
Shop #: WSC 13765
Address 17: Instruments Labels: None
Part No: 6Y2 919 850 C
Component: KOMBIINSTRUMENT VDO V09
Coding: 16441
Shop #: WSC 23032
TMBNC46Y523398373 SKZ7Z0A1112509
No Faults Found
or DTCs not supported by controller
or a communication error occurred
Address 19: CAN Gateway Labels: 6N0-909-901.LBL
Part No: 6N0 909 901
Component: Gateway K<->CAN 1S31
Coding: 00013
Shop #: WSC 13765
Address 25: Immobilizer Labels: None
Part No: Bitte Adress
Component: e 17 eingeben
No Faults Found
Address 44: Steering Assist Labels: None
Part No: 6Q0 423 156 H
Component: LenkhilfeTRW V200
Coding: 00110
Shop #: WSC 00000
Address 46: Central Conv. Labels: 6Q0-959-433.LBL
Part No: 6Q0 959 433 E
Component: 31 Komfortgerát 0001
Coding: 00067
Shop #: WSC 13765
Part No: 6Q2959802
Component: 31 Tőrsteuer.FS TFK 0002
Part No: 6Q2959801
Component: 31 Tőrsteuer.BF TFK 0002
Chris_55 is offline
Old 10-12-2007, 01:57   #12
Theresias's Avatar
Yep, does help.
Your cluster is one of the early ones which don't support this feature.
FWIW, the 6Y0-920-???-??? clusters do support it.
Sebastian
Similar Threads
Dash Warning light speednut Octavia II 9 28-08-2007 07:20
Circular warning light on the dash kenobi Superb 8 02-11-2006 15:43
Drivers Door Interior Light & Dash light Not Coming On ? jase555 Octavia I 3 30-11-2005 12:35
dash warning light triple7 Octavia I 7 05-10-2005 19:52
