40,613 Members 1,518,165 Posts
Driver's door not opening
This is a discussion on Driver's door not opening within the Diagnostics & VAG-COM forums, part of the General Motoring Discussions category; Help I've just fitted new central lock/ window motor as it went faulty and caused windows to come done (car ...
Old 25-01-2008, 12:06   #1
Members Car: octavia rs (yellow)
Help
I've just fitted new central lock/ window motor as it went faulty and caused windows to come done (car got soaked) and drivers door wouldn't lock with keyfob.
I had to take fuses out to stop car unlocking but after fitting new window/locking unit and put fuses back in the Windows worked and so did all the door locks bar the drivers door. Then the dash light wouldn't work then Aircon blower didn't work.
I mucked about a few times and finally got dash and blower working
(by the way took reversing light fuse out and the speedo stoped working as needed it to get blower working till i got home as steamy windows) now the airbag warning light is on but everything else is working bar the Drivers door lock by keyfob.
Has anyone had this type of trouble, what would cause the lock motor not to work as tested with a circuit tester and seems to be getting power (tried other motor and that didn't work either) and why would fuses affect other systems that badly when removed then replaced??
Please anyone got any Ideas Thanks
yellotaxi is offline
Similar Threads
Driver's door glass, won't go up skodaiw Octavia I 1 30-08-2007 12:56
fabia front door light problem related with opening of fifth door samy1 Maintenance & Performance 0 29-11-2006 00:09
Driver's door lock solenoid scary-bob Favorit, Felicia, Fun and Forman 5 05-11-2006 23:34
Driver's door lock paulj Maintenance & Performance 1 20-10-2004 20:24
Driver's Door Lock Aggravation! devonutopia Maintenance & Performance 26 20-08-2003 15:23
