40,612 Members 1,518,139 Posts
DTC17748 detected on 1.8T
This is a discussion on DTC17748 detected on 1.8T within the Diagnostics & VAG-COM forums, part of the General Motoring Discussions category; Hi The following error has been detected on my car Control Module Part Number: 06A 906 032 T Component and/or ...
Old 26-08-2004, 10:32   1 links from elsewhere to this Post. Click to view. #1
Members Car:
Hi
Component and/or Version: 1.8L R4/5VT 0003
Software Coding: 05510
Work Shop Code: WSC 33103
1 Faults Found:
17748 - Camshaft Position Sensor (G40) / Engine Speed Sensor (G28): Incor. Correlation
P1340 - 35-00 - -
What could be the problem?
I drive a Leon 20VT Sport, AUQ engine code so is the same as the Octy vRS.
Any help will be much apreciated
tonipieleanu is offline
Old 26-08-2004, 10:51   #2
DGW
BRISKODA Staff
DGW's Avatar
Here is another decode of the error from Bentley Publishers VW Diagnostic Trouble Codes table:
DTC 17748: Crankshaft-/Camshaft Pos.Sens.Signals Out of Sequence
Denis
2007 Fabia vRS - CC, ESP and full leather trim by Seat Surgeons ...48.12mpg...
DGW is offline
Old 26-08-2004, 11:25   #3
Tavia4x4's Avatar
Members Car: Mini Breadvan
Is easy to replace and not uncommon to fail..
(mine went at 63k)
Ian
Nice to be important, but more important to be nice...
Tavia4x4 is offline
Old 26-08-2004, 13:53   #4
DGW
BRISKODA Staff
DGW's Avatar
An impulse sender crankshaft for the AUQ is £73.00.
Denis
DGW is offline
Old 26-08-2004, 14:17   #5
Members Car:
(mine went at 63k)
What fails? The camshaft position sensor or the engine speed sensor?
Did your car react in anyway? My car seems to run fine.
Did you feel any loss of power or any other strange thing?
Old 26-08-2004, 14:24   #6
Tavia4x4's Avatar
Seemed to run fine but had some other major problems at same time - don't *think* they were related but I would advise do it very soon nonetheless!
(camshaft position sensor)
Ian
Tavia4x4 is offline
Old 12-05-2006, 22:15   #7
Members Car: 2002 Octavia RS
Re: DTC17748 detected on 1.8T
I get the same 17748 error on my RS. Is it enough to replace the Camshaft Positions Sensor?
Anyone here has a guide on how to do it?
Regards, Martin
MartinDK is offline
Old 12-05-2006, 22:22   #8
Regards, Martin
MartinDK is offline
Old 12-05-2006, 22:23   #9
Partner
Lummox's Avatar
Images: 2
Has the cambelt been changed?
That corrolation fault is not a sensor fault usually, its picking up that the cam and crank are out of sync.
www.unit18.co.uk
Lummox is offline
Old 12-05-2006, 22:29   #10
Partner
Lummox's Avatar
Images: 2
See here...
http://www.briskoda.net/forums/octav...hlight=cambelt
www.unit18.co.uk
Lummox is offline
Old 12-05-2006, 22:31   #11
Regards, Martin
MartinDK is offline
Old 12-05-2006, 22:37   #12
Originally Posted by Lummox
Yes the error occured after a cambelt ****. If they where out of sync the engine would not run fine?? The engine runs fine.
Can it be synced in any other way that just checking that the belt sits as the old belt did??
So I shouldnt change the sensor? Further up in this thread a sensor shift is suggested .... im confused...
Regards, Martin
MartinDK is offline
Old 12-05-2006, 23:21   #13
Partner
Lummox's Avatar
Images: 2
I suspect the cam sensor was changed on Tavia 4x4's car for a different reason.
www.unit18.co.uk
Lummox is offline
Old 18-05-2006, 18:45   #14
Jelly Mould
fordfan's Avatar
Members Car: Ford
I agree with Lummox as it a synchronisation fault the belt will be a tooth out. Had this one before from experience, the technician swore blind that the new belt ent on in exactly the correct position, on inspection it was a tooth out.
fordfan is offline
Old 18-05-2006, 18:51   #15
Partner
Lummox's Avatar
Images: 2
This was found to be the case in the other thread, its fairly obvious when you look at what the fault is actually saying. Its not saying there is a fault with the sensors, its saying there is a fault in what the sensors are seeing.
www.unit18.co.uk
Lummox is offline
LinkBacks (?)
LinkBack to this Thread: http://briskoda.net/diagnostics-vag-com/dtc17748-detected-1-8t/13833/
Posted By For Type Date
Sporadic EPC Light 1.8T - Passat World Forums This thread Refback 03-10-2006 20:44
Similar Threads
ECU Explorer AwesomeAPR Awesome GTI 14 02-12-2004 12:01
Hard Starting Problem With 1.8t Turbo_Boss Maintenance & Performance 19 25-01-2004 17:17
Googlisms! Tavia4x4 Off Topic and Chit Chat 46 30-10-2003 17:49
1.8T 150 & 180bhp engines - difference? Fabpreza General Car Chat 43 05-10-2003 20:50
How do the 4 versions of the 1.8T engine fitted to the UK Octavia differ? DGW Maintenance & Performance 1 15-08-2003 12:30
