40,614 Members 1,518,180 Posts
Dump Valve Problems?
This is a discussion on Dump Valve Problems? within the Diagnostics & VAG-COM forums, part of the General Motoring Discussions category; Recently my engine warning light has been coming and coming. One time last week after turning the key the engine ...
Old 23-01-2005, 12:06   #1
day tripper's Avatar
Members Car: Suzuki Ignis Sport
Thumbs down Dump Valve Problems?
One time last week after turning the key the engine was fluctuating really badly revs going really low to around 300rpm to 1500rpm. The engine nearly cut out and the interior light nearly went out.
I took it to a friend the other day was it was checked on the diagnostics, it showed that the forge dump valve had made the light come on.
Does anyone know why?
day tripper is offline
Old 23-01-2005, 12:30   #2
Txt Spk Police
VRStu's Avatar
Members Car: Audi S3
Phone the guys at Forge they will advise you and take the valve in for service - normally FOC.
Although - re-reading your post, I don't think the valve would cause that, I think they are fobbing you off mate.
The DV is held closed by spring pressure until you lift off the throttle. The turbo wouldn't be on boost at idle and therefore that system would not be in use
Stu
VRStu is offline
Old 23-01-2005, 13:32   #3
Partner
Lummox's Avatar
Images: 2
But if the DV isnt sealing completely then un metered air is drawn into the inlet, this can cause idle problems.
I'd strip the DV down and give it a service myself.
www.unit18.co.uk
Lummox is offline
Old 23-01-2005, 13:36   #4
Txt Spk Police
VRStu's Avatar
Yeah, good point Ross. Didn't think of that doh!!
The problems with piston valves are piston wear and the grease causing it to become sticky.
Stu
VRStu is offline
Old 23-01-2005, 14:42   #5
jason's Avatar
Members Car: skoda octavia VRS
i had the same problem ,but not enough to get the lights on, forge 006 was as dry as a bone inside,quick clean and a bit of light greasing had it cracked
louder than war
jason is offline
Old 27-01-2005, 00:29   #6
Well ive emailed forge who have sent me a service kit which consist of red grease, ring/seals and some metal thing, any ideas on what im supposed to do? (havent had the chance to look at it yet)
Old 27-01-2005, 00:31   #7
MonkeyHanger's Avatar
Members Car:
Forge DV Service Intructions.
http://www.forgemotorsport.co.uk/valve_service.pdf
MonkeyHanger is offline
Old 27-01-2005, 02:06   #8
fully boyced.
boyced's Avatar
Members Car: Octavia vRS
do dv30's also need servicing?
boyced is offline
Old 27-01-2005, 18:39   #9
K44 ENT's Avatar
Yes they can be serviced, not sure how often but spoke to them when I fitted my DV30 to find out what lubricant they use. Was told it was a "seceret recipe" and that they will service the valve if I sent it back when the times comes, although they have some valves returned for servicing a few years old/50,000 miles with the original lubricant in and still working fine
Red Octavia vRS
SOLD...Still got the TVR
K44 ENT is offline
Old 27-01-2005, 22:30   #10
Thanks Geoff thats exactly what im looking for.
Old 28-01-2005, 12:18   #11
Clarey's Avatar
Members Car: skoda
Double check all the hoses around the intake and TIP. I had a hose come off (my own fault )which led to really bad idle at start up, but run ok after 30 secs or so, with no check engine light. Dealers had it overnight and couldn't find a problem
As Ross says, unmetered air entering is a possibility.
Cheers,
Phil.
Clarey is offline
Old 29-01-2005, 23:33   #12
Ive still not had time to service the dump valve yet, but when i started it up today, the same thing happened, i pressed the accelerator to rev it but there was no response whatsoever, stomped on the pedal a few times and it was ok...
Old 23-02-2005, 10:28   #13
Right ive put the stock dv back on for now, was ok for 2 days and the same thing happened the other day,fluctuating between 350-700rpm on startup????
Old 23-02-2005, 18:39   #14
Members Car: Occy VRS
What was the code that showed on the diagnostics?
www.fasterbaby.co.uk
www.ulcebybengals.co.uk
My gallery
Ex Octavia Vrs, now Volvo 850 T5 Rica'd to 304 bhp.
Fasterbaby is offline
Old 23-02-2005, 18:44   #15
fully boyced.
boyced's Avatar
7.
boyced is offline
Old 23-02-2005, 20:47   #16
I dont have a clue what the code was, gonna check it again shortly, ill let you know.
Sure its not a coil pack or maf?
Similar Threads
EVO dump valve sdmegawuk Maintenance & Performance 3 29-02-2004 00:29
Dump valve from Golf 1.8T MK1Man Maintenance & Performance 6 26-02-2004 10:18
Dump Valve Problems ChrisYeow Maintenance & Performance 23 09-01-2004 00:03
