This is a discussion on Ebay cable drivers, help please within the Diagnostics & VAG-COM forums, part of the General Motoring Discussions category; I bought the cable from eBay, i only want to check whats wrong with my girlfriends Fabia so i can ...
| Woof! Join Date: Sep 2006 Location: From Leeds, Live in Swansea
Members Car: 2008 Fabia3 1.9Tdi Estate Images: 7 Thanks: 50
| Ebay cable drivers, help please I bought the cable from eBay, i only want to check whats wrong with my girlfriends Fabia so i can take it to a garage, so didnt feel the need to spend lots on the full software. Only problem is i got a bit over zealous and threw away the jiffy bag, not realising the driver CD was inside. Ive installed vagcom 409.1 but the computer wont realise the cable. Could anyone else who has bought the ebay cable please send me the files that were on that CD if possible? It would be greatly appreciated. |
| Need more power Join Date: Feb 2007 Location: Driffield, Good old yorkshire
Members Car: Octavia VRS Thanks: 55
| Re: Ebay cable drivers, help please Which seller is the item from or a link would be handy.
__________________ Regards Martin Turbo back blueflame exhaust |
| Briskodian Join Date: Sep 2007 Location: East Ayrshire, Scotland
Members Car: Fabia VRS Thanks: 52
| Re: Ebay cable drivers, help please Yeah knowing where you bought the cable from might help. If you have plugged in the cable though and its not working, try heading over to Device Manager. There will be a yellow exlamation mark against it as no drivers have been installed. Right click the problem item and select update driver. You will have to be online for this. Windows should then find the appropriate driver(s). Then its just a case of setting it up in Vag - Com. Regards |
| Re: Ebay cable drivers, help please Cheers for the help guys, ill try this tonight when im back from work. Sorry i bought it froma seller called szhid, mluton is e-mailing me some drivers. So hopefully all will be well tonight. |
| Re: Ebay cable drivers, help please thats the same seller as i got mine from. Let of know if you need the original drivers as i thought mluton got his from alphabid.
| The Following User Says Thank You to martziniuk For This Useful Post: | snownrock (18-08-2008) |
| Re: Ebay cable drivers, help please Will do, ill see if his work, any probs and ill give you a shout, cheers for that. |
| ebay or other cheap vag com cable recommendation needed-Moved | farcrygamer | Diagnostics & VAG-COM | 13 | 12-08-2008 03:24 |
| drivers door and drivers mirror not working | switch400 | Octavia I | 6 | 29-06-2008 10:01 |
| Whos has a USB VAG-COM cable from EBay? | Goochie | Diagnostics & VAG-COM | 31 | 22-11-2006 07:03 |
| Cable Drivers | silvervrs | Diagnostics & VAG-COM | 1 | 17-12-2005 12:03 |
