40,613 Members 1,518,156 Posts
ECU Swap, whats the procedure?
This is a discussion on ECU Swap, whats the procedure? within the Diagnostics & VAG-COM forums, part of the General Motoring Discussions category; i'm trying to do an ecu swap on a Fabia 100PD, i have both ecu's and both key tags with ...
Old 19-11-2006, 19:49   #1
Old Skool Fan
ninja_alex's Avatar
Images: 14
i'm trying to do an ecu swap on a Fabia 100PD, i have both ecu's and both key tags with the 4 digit codes. Looked on Ross Tech website but only lists using 7 digit SKU's.
I know it can be doen but can anyone enlighten me as to the correct rpocedure to get the old ecu to work in the new car?
Alex
ninja_alex is offline
Old 19-11-2006, 19:58   #2
Txt Spk Police
VRStu's Avatar
Members Car: Audi S3
Re: ECU Swap, whats the procedure?
Alex as far as I know it is the same procedure but Skuds only used the 4 digit SKC. I know Bas has succesfully done it with two Fabia RS ECU's and I think Jason may have done it too.
Stu
VRStu is offline
Old 20-11-2006, 04:40   #3
Hardcore
Basil's Avatar
Members Car: Fabia vRS
IIRC - log in with a 0 before the code for newly installed ECU, then use the 4 digit code of the removed ECU without the 0 to adapt it.
POC
HTH
Bas
Fab vRS - Black Magic - PD160 intake - Forge FMIC - colour coded front grille -SLC Splitter - K&N Airfilter -SEAT Strutbrace - Jabba ARB - IC Waterspray (need to wire it in!) - 312mm TT brakes - Eibach Springs - Skoda Reversing sensors - Devonutopia Tuning (tm) Custom Exhaust (2 1/4" straight pipe) - Short shifter mod- 5 brake light mod - Helix Steel SMF + Organic Clutch + pressure plate - Peloquin LSD - TD stage 2 Hybrid - Washbrook remapped ECU - Uprated injectors - Cupra bushes -Poly-filled dogbone - Allard racepipe - Pirelli Dragons - Forge Rear Strutbrace - DIY SS upper boostpipe delete -Koni FSD's - elephant pipe CCV mod
Basil is offline
Old 20-11-2006, 14:21   #4
Old Skool Fan
ninja_alex's Avatar
Images: 14
Basil
In which areas of Vag Com are we talking about?
Alex
Old 20-11-2006, 14:24   #5
EddyH's Avatar
Members Car: Audi A6
Check my instrument cluster swap guide, the procedure for using the 4 digit SKC is in there.
EddyH
Audi A6 Avant 2.7 TDI
Audi A3 2.0 TDI Sport
EddyH is offline
Old 27-11-2006, 18:57   #6
Old Skool Fan
ninja_alex's Avatar
Images: 14
HELP
Can't get it to work. Got the codes, even had them checked by my dealer!
Plug the 'new' ecu into the car, immobilizer light flashes and cannot log into it.
What is the exact procedure? Been following the Ross Tech guide but using the 4 digit code with a 0 in front of it. VAGCOM tells me i need to switch off the car for 2-3minutes before trying again.
What am i doing wrong?
Alex
Old 27-11-2006, 19:18   #7
Hardcore
Basil's Avatar
First of all Alex - take a deep breath. You can do it easily. I stored a note on how on my work PC. Unfortunately SWMBO ditched the paper copy I had here at home!
I think it may be a double '0' or no '0' at all in front of the initial logon then the opposite on the second logon. I fiddled for a frustrating half an hour before I suceeded.
Open a beer, try different combos of prefix '0', '00' and none. It will kick you out until you suceed. When you get it right, celebrate and post it up here.
HTH
Bas
Basil is offline
Old 27-11-2006, 19:34   #8
Old Skool Fan
ninja_alex's Avatar
Images: 14
If the max is 5 digits, surely it can only be 1 zero or no zero, tried both of these combos. Could it be anything else? Also, this is inputted in the main vagcom screen not in the 'use SKZ code' box where you need dates and dealer codes etc
Old 27-11-2006, 20:02   #9
Hardcore
Basil's Avatar
IIRC - you do input them in the 'use skz code' - no dealer code or date need be inputted. Leave them blank.
IIRC, what you do is:
[Select]
[01 - Engine]
[Login - 11]
[Use 7-digit PIN/SKC]
Enter the 5-digit PIN from ECU #2,
[OK]
[Do-It!]
[Adaptation - 10]
Enter 50 in Channel Number
[Read]
Enter the 4-digit PIN from ECU#1,
[OK]
[Test]
[Save]
[Done, Go Back]
If you can hold on for a day, I'll send you the procedure as I have it saved at work. I did this a few months ago...
HTH
Bas
Basil is offline
Old 27-11-2006, 20:11   #10
Old Skool Fan
ninja_alex's Avatar
Images: 14
Cheers Baz, been doing it slightly wrong, using the wrong areas of Vagcom by the looks of it!
Alex
Old 27-11-2006, 20:15   #11
Hardcore
Basil's Avatar
Talking Re: ECU Swap, whats the procedure?
You da man Alex
Basil is offline
