40,613 Members 1,518,158 Posts
electronic engine control light
This is a discussion on electronic engine control light within the Diagnostics & VAG-COM forums, part of the General Motoring Discussions category; just adjusted the strutbrace and now the electronic engine control light is on help me what do i do !!! ...
Old 30-09-2004, 18:06   #1
mcbunny's Avatar
Members Car: Brabus Roadster Coupe
i did unplug one plug the one marked in red on the pic
mcbunny is offline
Old 30-09-2004, 18:07   #2
MonkeyHanger's Avatar
Members Car:
Unplug it, and plug it back in again.
Check that no dirt has got into the contacts.
Hope you didn't pull it by the wiring..
MonkeyHanger is offline
Old 30-09-2004, 18:31   #3
Members Car:
Find someone local with Vag-Com. Read the code and reset it. If it doesn't reappear breathe a sigh of relief. Should be just a glitch ( ignition wasn't on when you disconnected it was it? ) If light comes back on the Vag-Com will point you in right direction. I'm just south of Aberdeen if that's any use to you.
Pete
tuscan30 is offline
Old 30-09-2004, 18:39   #4
mcbunny's Avatar
i dont think it was fully on when i started it up
its gone now as i unplugged the other side lol (silly i know) maybe when i had been moving it around the other connector with all the pipes had moved a bit but no light is on now thank god.
aberdeen is a bit far tho bud even tho im up in ayr tomorrow from york
its off into the dealer tomorrow as well
mcbunny is offline
Old 30-09-2004, 18:53   #5
In an emergency, For future reference you can clear the "check engine light" by disconecting the battery for a few minuites, If it dosent come back on the problem was intermittent if it comes back on again then you have a problem. BEST way is still to get to someone with vag com or the dealer as they can read the fault code before re-setting it
The AA can also read it with their diagnostic equipment, for those with a 4x4 its not listed on the AA list but enter Octy rs, it works
Speed is an addiction for which thankfully there is no cure
Stuart_J is offline
Old 30-09-2004, 19:16   #6
Members Car:
First time I had an engine management light come up I hi-tailed it to the local dealership. Twenty seven quid later they said there was nothing recorded in the ECU's memory. Don't quite understand the logic here - SOMETHING must have tripped the light and that means something is recorded in the fault log.
Point is - it doesn't take many trips to the dealers before you've spent the money that a vag-com costs. Wouldn't be without a V-C now.
Cheers,
Pete
tuscan30 is offline
Old 01-10-2004, 06:01   #7
Cheers,
Pete
Change dealers !, mine has done it twice FOC, both times it was due to a leaking joint on the Exhaust I had added to the car causing an emission error. Theyve also had the car in & road tested it etc for suspected wheel bearing failure to find that the Woolfrace wheels had buckled, again no charge. Looks like my dealers a gem & I didnt even buy either Skoda from them.
Stuart_J is offline
Old 01-10-2004, 09:03   #8
BRISKODA Staff
SkodiRS's Avatar
Members Car:
Stu,
which dealer is this?
Cheers.
Adrian.
Adrian.
SkodiRS is offline
Old 02-10-2004, 09:10   #9
Cheers,
Pete
That sounds like a handy gadget. How much? Where from? How easy is it to use
Bomber is offline
Old 02-10-2004, 09:44   #10
Members Car:
There's a comprehensive "sticky" at the top of the Diagnostics forum that gives details of several suppliers. Ross Tech seems to be the most focussed. Prices range from a couple of quid on eBay (take your chance !) to around 50 quid from OBD.com and Ross Tech a bit more. Software varies depending on whether you go for the limited option of shareware (you don't get all the functions - but still pretty useful) or spend the extra 99 dollars on the full singing and dancing package with support and updates. Make sure you get a cable that is compatible with your laptop - either serial or USB cos they don't mix.
Ease of use ? Very easy mostly. The programme advises you what is safe to look at and what is best left alone unless you have specialist knowledge.
Cheers.
Pete
tuscan30 is offline
Old 02-10-2004, 10:28   #11
Cheers.
Pete
Thanks
Ian
Bomber is offline
Similar Threads
Introduction to the Fabia ColinD Fabia I 17 17-12-2007 14:11
Introduction to the NEW Octavia ColinD Octavia II 2 22-02-2007 20:09
Introduction to the Octavia ColinD Skoda History 0 03-06-2004 11:22
Introduction to the Superb ColinD Skoda History 0 03-06-2004 11:21
New Octavia In Detail ColinD General Car Chat 0 22-04-2004 12:18
