This is a discussion on engine coolant temperature sensor within the Diagnostics & VAG-COM forums, part of the General Motoring Discussions category; could anyone help as to where i can purchase a new one of these as skoda have quoted me £100 ...
| Briskodian | engine coolant temperature sensor could anyone help as to where i can purchase a new one of these as skoda have quoted me £100 and i think this is rediculous ![]() |
| Need more power Join Date: Feb 2007 Location: Driffield, Good old yorkshire
Members Car: Octavia VRS Thanks: 55
| Re: engine coolant temperature sensor This should fit eBay.co.uk: GENUINE, VW, AUDI, SEAT, SKODA GREEN 4 PIN TEMP SENSOR (item 270137987970 end time 06-Jul-07 19:41:09 BST) I cannot believe skoda quoted you that much, Are you sure it was that part that you needed as £100 sound very expensive. |
| Briskodian | Re: engine coolant temperature sensor Hope this helps, my sensor replaced twice and did not cure problem in end needed whole thermostat, sensor is part of it anyway,£100 seems about right. Thermostat omplete is not much more but luckily mine was under warranty. Howeverit is 1.4 petrol. Thermostat problem is common. |
Members Car: Black Magic Fabia vRS Thanks: 385
| Re: engine coolant temperature sensor Assuming it's not massively different on your Octy to a Fabia, the sensor should cost about £25 from a dealer, and the complete thermostat not more than £35. Replacement of the sensor is a very easy to easy DIY job, depending on the model, but definitely worth doing if you're watching the pennies! I gather it's not significantly harder to do the whole thermostat assembly. In either case, you may need to drain the coolant, which is an extra expense, I suppose that will be included in the dealer's quote. And labour of course. The ebay sensor is therefore cheaper, but the only thing I'd say about it is that it's green and supposedly replaces blue and black ones. The one I got from a dealer six months or so ago was light grey (as was the one I removed, in fact), so it may or may not have been newer than the green ones. Someone on here with more knowledge should be able to confirm or disprove that, if you're concerned...
__________________ Last edited by ap0gee; 29-06-2007 at 10:51. Reason: dab seppling ;) |
Members Car: Audi S3 Thanks: 195
| Re: engine coolant temperature sensor I think the £100 may have included fitting.
__________________ Stu Stu's Websites - http://www.fabia-vrs.com & http://www.octavia-vrs.com Stu's Car - 2008 Audi S3 - Ibis White, Black Optics Pack, Privacy Glass, Auto Bi Xenon Headlights, Rain Sensing Wipers, Bose Sound System, Ipod Prep, GSM Phone Prep, Flat Bottom Multi Function Steering Wheel, Electric Folding Mirrors, Acoustic Parking, Cruise Control, Interior Light Pack, Non Smokers Pack. SWMBO's Car - 2008 Seat LEON TDi Stylance, Black Magic, Sports Pack, Rear Parking Sensors. Something for Weekend - A Patio |
