40,609 Members 1,518,006 Posts
errors today... help
This is a discussion on errors today... help within the Diagnostics & VAG-COM forums, part of the General Motoring Discussions category; Address 03: ABS Brakes Control Module Part Number: 1K0 907 379 AC Component and/or Version: ESP FRONT MK60 0101 Software ...
Old 10-11-2007, 15:50   #1
2.0 FSI Sport.
smstext's Avatar
Members Car: Octavia Mk2 FSI Sport
Software Coding: 0004738
Work Shop Code: WSC 73430
2 Faults Found:
01435 - Brake Pressure Sensor 1 (G201)
005 - No or Incorrect Basic Setting / Adaptation
01423 - Lateral Acceleration Sensor (G200)
also have the icons lit on the dashboard.
smstext is offline
Old 10-11-2007, 17:40   #2
Jelly Mould
fordfan's Avatar
Members Car: Ford
Re: errors today... help
Have a look here:
01423 - Ross-Tech Wiki
and
01435 - Ross-Tech Wiki
fordfan is online now
Old 10-11-2007, 18:23   #3
2.0 FSI Sport.
smstext's Avatar
yeah tried there not much help... got a 1044 now instead... hold on.... nope cleared them all but not happy with the long coding used to clear them but now i dont have abs, traction control and tpm light lit on the dashboard and can now turn esp on/off and set my tyre pressure
smstext is offline
Old 10-11-2007, 18:46   #4
Theresias's Avatar
Members Car: MY 2007
I've updated both codes pages regarding your specific code. Have you performed the basic setting yet?
VW Golf (1K) Brake Electronics (MK60) - Ross-Tech Wiki
Did you recode the module so the 01044 has a reason? Or is it all fixed now?
Sebastian
Theresias is offline
Old 10-11-2007, 18:57   #5
2.0 FSI Sport.
smstext's Avatar
[Select]
[03 - Brake Electronics]
[Coding-II - 11]
OR (if Coding-II is not available)
[Security Access - 16]
Enter 40168, to enable the basic setting.
[Do it!]
[Basic Settings - 04]
Group 060
[Go!]
Activate the Basic Setting.
[ON/OFF/Next]
After a successful basic setting, field 2 should say "OK".
At this stage i get " error group 060 not available" written in red through the four boxes.
smstext is offline
Old 10-11-2007, 19:09   #6
Theresias's Avatar
Did you do the coding 2/security access before and entered the group number in basic settings and NOT measuring blocks?
Sebastian
Old 10-11-2007, 19:12   #7
2.0 FSI Sport.
smstext's Avatar
yes i followed the instructions that stu gave me which now look the same as the ones on your site... as stu is away i cant keep ringing him up as its not fair on him. all this is because the maxidot failed when installed this morning. btw i have a micro-can and running on version 710
smstext is offline
Old 10-11-2007, 19:22   #8
Jelly Mould
fordfan's Avatar
Members Car: Ford
The group for coding G201 is 066 not 060 according to the instructions.
Old 11-11-2007, 01:37   #9
2.0 FSI Sport.
smstext's Avatar
these were my instructions on what needed to be done after the maxidots were fitted this morning...
Sensor for Steering Angle (G85)
Prerequisites:
Start the vehicle.
Turn the steering wheel one turn to the right and one turn to the left.
Drive in a short distance straight line on a level surface at a speed not higher than
20 km/h.
If the steering wheel is straight during the test drive then stop the vehicle with the
wheels pointed straight.
Ensure that the steering wheel is not moved again.
Keep the engine running and do not switch off the ignition.
[Select]
[Coding-II - 11]
OR
[Do it!]
Group 060
[Go!]
[ON/OFF/Next]
[Done, Go Back]
To make sure the basic setting was succesful, check the sensor again.
[Measuring Blocks - 08]
Group 004
but everytime i tried to do the on/off button bit that was when i has the problems.
smstext is offline
Old 11-11-2007, 03:49   #10
bearthebruce's Avatar
Members Car: 2006 Audi A4
Fordfan seems to be correct. The procedure you need to use for the brake pressure sensor G201 uses group 066 - at least the updated info Sebastian posted would indicate that that is the case. Check the Ross-Tech Wiki again.
-Bruce-
Ross-Tech, LLC
bearthebruce is offline
Old 11-11-2007, 08:58   #11
Txt Spk Police
VRStu's Avatar
Members Car: Audi S3
There wouldn't have been any need to change any long or short coding so if you have then you need to change it back.
Stu
VRStu is online now
Old 11-11-2007, 09:04   #12
Theresias's Avatar
I guess we should start all over again...
...please post a fully Auto-Scan so we can see what exactly is up to the car currently and what is installed.
Sebastian
Old 11-11-2007, 14:12   #13
2.0 FSI Sport.
smstext's Avatar
ill try and print one off later... personaly i dont want to go back near the car as im fed up with it.
that is the screen shot of what im discribing above when i clicked the on/off/wotsit button as per instructions.
smstext is offline
Old 11-11-2007, 17:48   #14
Txt Spk Police
VRStu's Avatar
Sebastian
Paul was supposed to have had a replacement DashPod fitted on Saturday and thus requires the basic settings carried out on the car. They didn't get the dashpod working.
I've done it several times using the guide on the Wiki but it does often take a couple of attempts.
Stu
VRStu is online now
Similar Threads
Search errors! vrs jamez27 Suggestions & Site Issues 1 22-05-2007 23:50
Too Many Communication Errors Joey122mac Diagnostics & VAG-COM 9 12-01-2007 15:02
