40,613 Members 1,518,158 Posts
Exhaust Gas Recirc. Sensor (A) Circ High Input
This is a discussion on Exhaust Gas Recirc. Sensor (A) Circ High Input within the Diagnostics & VAG-COM forums, part of the General Motoring Discussions category; Exhaust Gas Recirc. Sensor (A) Circ High Input Code 4196 The secondary air fan keeps filling with water , anyone ...
Old 01-02-2006, 11:57   #1
Members Car:
The secondary air fan keeps filling with water , anyone else had this problem?
I have replaced the fan checked the pipes, perhaps a combo valve fault?
Regards Keith 2001 VW golf GTI 20v 150BHP
crashmctavish is offline
Old 03-03-2006, 19:03   #2
Members Car:
Re: Exhaust Gas Recirc. Sensor (A) Circ High Input
I now have Intake Camshaft Contr.Circ.,Bank2 Short to B+ could this be a faulty dump valve?
Old 01-05-2006, 11:45   #3
Members Car:
dump valve replaced but it still comes up with the code about every two weeks, any advice glady received. Intake Camshaft Contr.Circ.,Bank2 Short to B+ also continues?
Old 01-05-2006, 11:52   #4
Briskodaholic
Tom_vRS's Avatar
Members Car: '97R BMW 328i Saloon
Hmmm, sounds like a strange one. Sorry I can't help, but welcome to Briskoda
97/R BMW 328i in Boston Green.
Tom_vRS is offline
Old 01-05-2006, 22:14   #5
Theresias's Avatar
Members Car: MY 2007
Seems that you are using a Bosch KTS tester or similar system that doesn't actually come up with standard VAG codes.
According to your 1st post, you did get 4196, which is not a VAG code, but based on the assumption that you are using a Bosch KTS, the correct VAG code is 16790 which would be shown as EGR Temp Sensor (G98): Signal too High by VAG-COM. So I checked a couple of 150 HP engines in question, but neither one of them has a G98, so either your ECU is defective or you posted a wrong fault code or your chiptuner did mess something up.
Since you did not post a fault code of the 2nd one (Intake Camshaft Contr.Circ.,Bank2 Short to B+) it's hard to help you on that, since the text varies between the tool manufacturers. So besides posting complete fault codes, it would be helpful to have the engine code of the car in question.
So 1st thing to do now is telling us which diagnostic tool you are using since the posted output doesn't seem to be correct.
Sebastian
Theresias is offline
Old 01-05-2006, 22:20   #6
Partner
Lummox's Avatar
Images: 2
Sounds like a wiring issue to me on the VVT solenoid for the second fault.
Short circuit to B+ usually indicates something is disconnected.
Not so sure on the EGR fault.
www.unit18.co.uk
Lummox is offline
Old 02-05-2006, 15:50   #7
Members Car:
Hi Guys thanks for your response so far. Im using a Gendan code reader which gives 4 figure codes. I agree with the diagnosis of the cam sensor I will look for a wiring fault with that.
On the other matter I have 4196 (16790)& 4529 (17705) (these persist)
Ive fitted a new dump valve & cleaned the MAF, as mentioned before I also replaced the sec air fan at a cost of £300!
The car suffers an occasional misfire from cold, just a stutter at low revs really, Ive checked all the coil packs and they are 2003 the car is 2001 so im guessing the are ok.
Old 02-05-2006, 16:00   #8
Theresias's Avatar
You should definitly try to read codes with a different tool, we've had more then one case yet where these hand held readers were wrong. Especially since I still can't find a G92 in a suitable 150 HP engine and you still didn't tell an engine code.
Sebastian
Old 02-05-2006, 17:47   #9
Partner
Lummox's Avatar
Images: 2
I'd agree with Seb on the EGR fault, ive never seen an EGR temp sensor on a petrol car.
www.unit18.co.uk
Lummox is offline
Old 04-05-2006, 08:45   #10
Members Car:
Ok thanks guys, its an AUM 20v Turbo lump, I will research & get back to you.
Cheers Crash
Old 04-05-2006, 09:06   #11
Theresias's Avatar
Get a real scan tool... An 1.8T (AUM) has no EGR (Exhaust Gas Recirc).
Sebastian
Old 06-05-2006, 10:08   #12
Members Car:
I sent your responses to gendan, they have been most helpful and are posting a cable for my laptop so i can use vagcom to check further.
Old 23-05-2006, 15:49   #13
Members Car:
The guys at Gendan spotted my error. The four figure code readers are Hex code (thats hexadecimal base 16) so its not 4196 but 419b which translates to secondary air fan flow fail. I.e its still filling with water or condensate. Combo valve eprhaps? any ideas chaps?
Regards Keith
Old 24-05-2006, 18:53   #14
Members Car:
I would leave it and go to the pub. JM.
jonm is offline
Old 24-05-2006, 19:18   #15
Partner
Lummox's Avatar
Images: 2
There is a fuse and relay for secondary air injection on the bulkhead just behind the airbox in a little relay carrier.
The relay can be activated via Final Control diagnosis (03) in the engine control unit with VAG COM.
www.unit18.co.uk
Lummox is offline
Similar Threads
Introduction to the NEW Octavia ColinD Octavia II 2 22-02-2007 20:09
allofmp3.com rich1068 The Tech Shed 26 20-12-2005 00:02
New Octavia In Detail ColinD General Car Chat 0 22-04-2004 12:18
