This is a discussion on extra VAG-COM settings for Fabia within the Diagnostics & VAG-COM forums, part of the General Motoring Discussions category; Here are some more Fabia ECU settings that can be programmed with VAG-COM. they come from OpenObd.org (Babelfish translated from ...
| Hardcore Join Date: Feb 2006 Location: Bahrain
Members Car: Fabia vRS Thanks: 209
| Here are some more Fabia ECU settings that can be programmed with VAG-COM. they come from OpenObd.org (Babelfish translated from German, but some parts really quite unclear). I have used some of the coding - changed country code, adjusted the highway flashers and the default wipers. However, my usual disclaimer applies. Cheers Bas {electrical system} STG 09 (electrical system) select STG coding - > function 07 Coding number (basis): 000000 +00016 - 4-tuerige execution +00128 - heatable outside mirrors +01024 - Tail cover remote unlocking remote operated +08192 - Rear windshield wiper with comfort circuit +16384 - Control electrical washer pump Controller adjustment STG 09 (electrical system) select STG Login - > function 11 Note: Before the adjustment a Login has to take place. Login code: 21343 STG adjustment - > function 10 - > channel 001 (clamp 30G) 30G clamping wedges – withdrawal?????? Range of values: 1-253 = 0,66-173 min/ Default value: 44 = 30 min - > channel 002 (heated windshield) Disconnection time of the heated windshield. Range of values: 1-253 = 0,66-173 min Default value: 29 = 20 min - > channel 003 (heated outside mirror) Disconnection time of the heated outside mirrors. Range of values: 1-253 = 0,66-173 min Default value (to 04/02): 29 = 20 min Default value (starting from 05/02): 254 (without disconnection) - > channel 004 (heated back window) Disconnection time of the heated back window. Range of values: 1-253 = 0,66-173 min Default value: 29 = 20 min - > channel 005 (boot remote unlocking) Time of the remote button press for boot remote unlocking. Range of values: 1-254 = 0.32-81.6 s Default value: 3 = 1 s - > channel 006 (comfort-flash) Number of flashing cycles for comfort flashers (highway) Range of values: 0 - 5 Default value: 3 - - > channel 007 (wiping wash mechanism) Number of wipes on spray. - Range of values: 0 -? Default value: 5 {combination instrument} Controller coding STG 17 (combination instrument) select STG coding - > function 07 ??xxx: Extra options and optional extras +00 - no extra options +01 - Brake lining wear announcement +02 - Seat belt warning +04 - Wiping water level warning +08 - does not occupy +16 - Activation clock in MFA xx?xx: Country selection 0 - Germany (D)- metric 24hr 1 - Remainder of the world (RdW) ??? 2 - THE USA (US)-imp 3 - Canada (CDN)- metric –12hr 4 - Great Britain (GB)- 5 - Japan (JP)-metric 6 - Saudi Arabia (SA)- metric –24hr- Speed chime at 120km/h 7 - Australia (OUT) – metric Controller adjustment STG 17 (combination instrument) select STG adjustment - > function 10 - > channel 30 (tank fuel sensor adjustment) The base value is 128 now can it in 1 ohm steps adjust, the respective maximum values is 120 and/or. 136. - > channel 50 (going away barrier) Login for the adaptation of the going away barrier, combination instrument to the engine expensive equipment. (??) {comfort system} Controller coding STG 46 (comfort system) select STG coding - > function 07 Central Locking (4-window): 00258 - Single door opening 00259 - Total door opening Controller adjustment STG 46 (comfort system) select STG adjustment - > function 10 - > channel 03 (auto-LOCK) The vehicle is locked at a speed of 15km/h (0 = OFF; 1 = ON). - > channel 04 (auto-UNLOCK) The vehicle is locked at a speed of 15km/h and unlocked after to taking out the ignition key (0 = OFF; 1 = ON). - > channel 05 (interior monitoring disconnection) Connection of starting from of the interior monitoring with twice operate of ZV (0 = OFF; 1 = ON). - > channel 06 (unlocking horns) Unlocking is confirmed with a short acoustic signal (0 = OFF; 1 = ON). Needs factory alarm - According to legislator in Germany not certified. - > channel 07 (locking device horns) Locking is confirmed with a short acoustic signal (0 = OFF; 1 = ON). - Needs factory alarm According to legislator in Germany not certified. - > channel 08 (unblocking flashing) The turn signals are operated when unlocking (0 = OFF; 1 = ON). - > channel 09 (bolting device flashing) The turn signals are operated when locking (0 = OFF; 1 = ON). - - > channel 10 (alarm horn) Land tuning of the alarm horn (1 = remainder of the world; 2 = Germany; 3 = GB). Affects kind, length and volume of the alarm tone (legal guidelines consider). x??xx: ESP (electronic stability program) Note: Over this place it is specified whether the guidance assistance has its own guidance angle sensor, or whether via CAN from the ESP will receive the signal. 01 - no ESP 12 – ESP xxx??: Program type 10 - Normally (heavy vehicles) 30 - Comfort (heavy vehicles) 40 - Normally (light vehicles) 50 - Comfort (light vehicles) 60 - Mobility assistance |
Members Car: Audi S3 Thanks: 195
| Re: extra VAG-COM settings for Fabia Nice one Bas, I'll add some of those ones you sent me to my website when time permits.
__________________ Stu Stu's Websites - http://www.fabia-vrs.com & http://www.octavia-vrs.com Stu's Car - 2008 Audi S3 - Ibis White, Black Optics Pack, Privacy Glass, Auto Bi Xenon Headlights, Rain Sensing Wipers, Bose Sound System, Ipod Prep, GSM Phone Prep, Flat Bottom Multi Function Steering Wheel, Electric Folding Mirrors, Acoustic Parking, Cruise Control, Interior Light Pack, Non Smokers Pack. SWMBO's Car - 2008 Seat LEON TDi Stylance, Black Magic, Sports Pack, Rear Parking Sensors. Something for Weekend - A Patio |
| | #3 | |
| Briskodian Join Date: Apr 2006 Location: Mid Germany
Members Car: MY 2007 Thanks: 1
| Re: extra VAG-COM settings for Fabia Quote:
__________________ Sebastian Last edited by Theresias; 28-04-2006 at 13:59. | |
| Re: extra VAG-COM settings for Fabia I do update regularly actually and always welcome new ideas or notes for correction. All information is provided in good faith on an 'as is' basis.
| Re: extra VAG-COM settings for Fabia What about setting up sth. real instead? http://wiki.ross-tech.com/index.php/...Fabia_%286Y%29 You will find a lot of the stuff which is currently on my original website their in a while and you will also find more than that, so it would be "thankful" to place links instead of leeching knowledge and work without a small note about the source.
__________________ Sebastian |
| Re: extra VAG-COM settings for Fabia I'm sorry if by starting this thread, I seem to have upset anyone. As you can see from the very first post - I acknowledge the source. Elsewhere on this forum I mention Sebastian at openobd.org as a wonderful resource. He has helped me several times by email - and is an expert non=pareil in this complex matter. I only wished to point out a great source of info. With over 11,000 members on Briskoda.net I only wish that an English Language version would be available. Babelfish does not do this valuable info a proper service. I really feel that Briskoda.net would be honoured by properly approaching this gentleman to see if he would be so kind as to provide a thread resource specific to our cars vag-com setups. Last edited by Basil; 29-04-2006 at 04:38. |
| | #7 | |
__________________ Stu Stu's Websites - http://www.fabia-vrs.com & http://www.octavia-vrs.com Stu's Car - 2008 Audi S3 - Ibis White, Black Optics Pack, Privacy Glass, Auto Bi Xenon Headlights, Rain Sensing Wipers, Bose Sound System, Ipod Prep, GSM Phone Prep, Flat Bottom Multi Function Steering Wheel, Electric Folding Mirrors, Acoustic Parking, Cruise Control, Interior Light Pack, Non Smokers Pack. SWMBO's Car - 2008 Seat LEON TDi Stylance, Black Magic, Sports Pack, Rear Parking Sensors. Something for Weekend - A Patio | |
| I am not comfortable with the direction this thread is heading. I consider Stu a friend - we've had more than a few msg's back and forth and I wouldn't allow anyone to say anything less than complimentary. The purpose of this forum is to provide information to members in a friendly manner. I would remind newer members that according to forum rules, any personal insults will result in banning. All the best, Bas Last edited by Basil; 29-04-2006 at 09:44. |
| 130bhp Join Date: Dec 2003 Location: Sheffield (UK)
Members Car: Skoda Fabia vRS Thanks: 0
| Re: extra VAG-COM settings for Fabia Thanks for the info... There are a couple of items I might consider, such as the amount of wipes when using the washer and different alarm tone. Thanks again. |
| | #10 | ||||
Anyway, think about the offer...! ![]()
__________________ Sebastian | ||||
| | #11 |
| Re: extra VAG-COM settings for Fabia Firstly you are assuming that the knowledge published was leached, possibly from openOBD.org and secondly you also seem to be assuming that every access code relating to VAG vehicles is the intellectual property of that website. Whilst I will agree that openOBD is a fantastic resource, and I congratulate you on it's content, I do take offence at the comments you make above regarding my website. It seems we will have to agree to disagree and continue in our own seperate ways. Do keep up the good work and in the future should you you wish to share information with me I would gladly include the necessary credits.
