40,613 Members 1,518,165 Posts
Fab VRS: Possible to disable ASR without the light on the dashboard illuminating?
This is a discussion on Fab VRS: Possible to disable ASR without the light on the dashboard illuminating? within the Diagnostics & VAG-COM forums, part of the General Motoring Discussions category; As title, really...
Old 03-12-2008, 15:24   #1
didn't burn him
Members Car: Skoda Fabia VRS
Images: 5
As title, really
Ed
I drive a Corrida Red 2004 Skoda Fabia vRS that has been retrimmed by the Seat Surgeons
Originally Posted by Frank Martin
Rule 1: Never change the deal. Rule 2: No Names. Rule 3: Never open the package.
Calculate approximate car running costs here | Support Briskoda & Join Freedom!
yegnold is offline
Old 03-12-2008, 15:25   #2
Theresias's Avatar
Members Car: MY 2007
Re: Fab VRS: Possible to disable ASR without the light on the dashboard illuminating?
Nope, why would one want to? Its a safety thing!
Sebastian
Theresias is offline
Old 03-12-2008, 16:19   #3
didn't burn him
Images: 5
I find that it cuts in too soon and prefer driving without it. I'm perfectly capable of preventing my wheels from constantly spinning with my foot
If it was ESP or a more advanced system then I'm sure I'd be more than happy to leave it as-is I just don't particularly like the way it suddenly cuts power to the wheels. Never used to bother me but since it's been colder and icier I've noticed it a lot more.
Having driven with ASR manually disabled and not having had any problems with wheel spin etc, I've concluded that it would not be a compromise on safety were I to totally disable it
Ed
yegnold is offline
Old 03-12-2008, 16:29   #4
Bored!
jaymd's Avatar
Members Car: Octavia VRS
Yes it is possible to disable it but i think the light will stay on.
Let me find the guide.
Will have to look tonight...i know it's something like fitting a resistor so that it's turned off all the time unless it's turned on.
jaymd is offline
The Following User Says Thank You to jaymd For This Useful Post:
yegnold (03-12-2008)
Old 03-12-2008, 17:04   #5
Hardcore
Basil's Avatar
Members Car: Fabia vRS
Smile Re: Fab VRS: Possible to disable ASR without the light on the dashboard illuminating?
I did some testing - there are some posts I did on Brisk - there is a resistor mod that works with older VAG cars but nogo on my 2005 vRS. An electronics expert could probably devise something more complex to trigger a relay momentarily timed a few seconds after you start up - but this would leave the light on.
Pulling the ABS fuse disables it totally, as it does the ABS system = not good.
The only practical way is to get it turned down/off by a tuner who knows what he is doing. I'd suggest approaching Richard Washbrook (oscarli.com) for advice.
"Safety device" in theory but it probably causes more accidents by suddenly cutting almost all power after a half second of wheelspin, leaving you halfway out entering a busy roundabout or intersection.
Easiest = just turn it off after you reach operating temps.....
HTH
Bas
Fab vRS - Black Magic - PD160 intake - Forge FMIC - colour coded front grille -SLC Splitter - K&N Airfilter -SEAT Strutbrace - Jabba ARB - IC Waterspray (need to wire it in!) - 312mm TT brakes - Eibach Springs - Skoda Reversing sensors - Devonutopia Tuning (tm) Custom Exhaust (2 1/4" straight pipe) - Short shifter mod- 5 brake light mod - Helix Steel SMF + Organic Clutch + pressure plate - Peloquin LSD - TD stage 2 Hybrid - Washbrook remapped ECU - Uprated injectors - Cupra bushes -Poly-filled dogbone - Allard racepipe - Pirelli Dragons - Forge Rear Strutbrace - DIY SS upper boostpipe delete -Koni FSD's - elephant pipe CCV mod
Basil is offline
Old 03-12-2008, 17:23   #6
Theresias's Avatar
Originally Posted by Basil View Post
...there is a resistor mod...
Which would still keep the warning light active and therefor does not really answer the original question.
Tuners do not mess with ABS systems as far as I am aware and disabling the engine control module functionality would be very questionable in my eyes.
Never heard of an accident which happent because of that, technically if this happens to you then you simply misjudged the weather/road conditions as well as the "gap" in traffic where you wanted to "slip" in. At the end its not the system which is faulty, its simply the driver who isn't able to control his gas foot...
Sebastian
Old 03-12-2008, 17:50   #7
didn't burn him
Images: 5
Erm...
Obviously for the ASR to kick in the wheels must have spun a little, but not very much. I find controlling a bit of wheelspin using throttle control much easier than dealing with the unexpected behaviour of the ASR system
Ed
yegnold is offline
Old 03-12-2008, 18:03   #8
Members Car: Renault megne
as above, i find it a bit of a pain, cuts power far to much. It has its uses, if you cant use your clutch verywell i guess.
matt1chelski is offline
Old 03-12-2008, 18:39   #9
Broken :(
Wardy's Avatar
Members Car: Skoda Fabia vRS
I disagree with that analysis. A problem can stem from the system cutting in too early, before it's strictly necessary. So where a slight amount of slip would have been fine and the driven wheels would have found traction again, the system cuts in, reduces power and can potentially put the driver in a situation where they wouldn't have been, had the ASR system not cut in.
Steve
Wardy's Fabia vRS
xenons : sunroof : cruise : OEM+
"Racing is life. Anything before or after is just waiting." - Steve McQueen
"If in doubt, flat out." - Colin McRae
Wardy is online now
Old 03-12-2008, 23:27   #10
King Rat
vRSLen's Avatar
Members Car: MK11 Octavia vRS
Whilst I quite agree Steve, the majority are fools .......
Current car: Black MKII Octavia vRS Combi
Previous: Black MKI Octavia vRS Combi
Black Fabia Elegance 100 BHP
vRSLen is offline
Old 03-12-2008, 23:40   #11
Broken :(
Wardy's Avatar
No doubt Len. Would still be nice to have the option though eh
I'm not too fussed about it these days anyway, as the EGR bypass has cut its presence back to an acceptable level.
Steve
Wardy's Fabia vRS
Wardy is online now
Old 03-12-2008, 23:41   #12
didn't burn him
Images: 5
Thanks people. I'll have a look in to the other benefits of an EGR bypass. For the moment I feel it would be a bit over the top as I'm not running a remap and am not using the new BLT engine which suffers from the stutter
Ed
yegnold is offline
Old 03-12-2008, 23:48   #13
King Rat
vRSLen's Avatar
As per the Bas mod I guess
vRSLen is offline
Old 06-12-2008, 11:42   #14
Babs's Avatar
ASR is rubbish!
The system on my 07 Fabia was better than my 54 Octavia though, the Fabia just lowered the power, but the Octy's left me sat on a roundabout before
- Andrew
In need of a new car, post your suggestions here!
Babs is offline
Old 06-12-2008, 13:10   #15
Why So Serious
fatty5000's Avatar
Members Car: a car
You can get it re-mapped in theory. Not sure about the flabia but the mk1 octy vrs can be told it's an S3.
fatty5000 is offline
Old 06-12-2008, 13:56   #16
Escorted Estate
I doubt you could tell the Fabia it was an S3
I did think the ASR was very much useless after having driven a demo car with ASR, and opted for the ESP option instead.
A Quaife or something would also sort it, but that's big money..
WW --->> Project Journal (pic links in first post there)
Lummox'/Ross thread on Unit18 Automotive progress on my car: here
WW_VRS is offline
Old 06-12-2008, 14:04   #17
Om nom nom nom
Neo_VR's Avatar
Members Car: A White Car
the esp/tc/diff on my car is very good.... not that it helps anything
ColGod the UberMod
,___,
[O.o]
/)__)
-"--"- ORLY??
Neo_VR is offline
Old 06-12-2008, 14:54   #18
Escorted Estate
You got the diff, which helps the TC/ESP with 'not' kicking in anyway
WW_VRS is offline
Old 11-12-2008, 05:20   #19
Hardcore
Basil's Avatar
To simulate ASR in a non-ASR equipped car, try turning off the ignition when getting onto a roundabout.
BTW did have a chat with my tuner, be of interest to see what he turns up...
Bas
Basil is offline
Old 11-12-2008, 11:55   #20
Site Sponsor
Members Car:
Audi did an A3 diesel quatto
Jabbasport is offline
Old 11-12-2008, 12:06   #21
Broken :(
Wardy's Avatar
Like hen's teeth though; I considered one before I got this Fabia. Especially in the previous 8L shape and sellers usually ask unreasonable amounts too!
Steve
Wardy's Fabia vRS
Wardy is online now
Old 11-12-2008, 14:23   #22
Site Sponsor
Members Car:
I was refering to using an Audi A3 Quattro 1.9 file in the fabia to give it a bit more of a forgiving ASR.
However, with the EGR delete pipe on i find the traction control is a lot less obtrusive, in fact, i left it on this morning whilst driving through icy back roads on the way to work..
So icy the ABS kicked in when you whispered on the brake and was still trying to spin the wheels at 1500rpm in 4th & 5th.
Old 11-12-2008, 14:32   #23
Ex Modder
Shifty's Avatar
Members Car: Omega 2.5 V6 CDX Auto
Images: 2
Bas
Haha perfect description Bas
<----- Add me on Xfire.
Everyone knows someone called Dave. That's me - I'm Dave™
Shifty is offline
Old 11-12-2008, 14:56   #24
Hardcore
Basil's Avatar
Smile
