40,609 Members 1,517,981 Posts
Fabia 1.4 16v mixture too lean
This is a discussion on Fabia 1.4 16v mixture too lean within the Diagnostics & VAG-COM forums, part of the General Motoring Discussions category; Hi all, I've just cleaned out my vgr pipe which was caked, now my engine light has stayed on this ...
Old 29-07-2008, 07:56   #1
Members Car:
Smile Fabia 1.4 16v mixture too lean
Hi all,
I've just cleaned out my vgr pipe which was caked, now my engine light has stayed on this time with a fault stating my mixture is too lean!
My light was on prior to me cleaning the said pipe only for flow too high which I gather is due to the blocked pipe.
could this mean there is an air leak in the pipe? or some other fault with the egr valve?
Any ideas folks?
Cheers
Johnr
Johnr990 is offline
Old 29-07-2008, 13:28   #2
Jelly Mould
fordfan's Avatar
Members Car: Ford
Re: Fabia 1.4 16v mixture too lean
Could you give us the exact fault code? It is feasible that the EGR valve is stuck, it can be checked and given a bit of 'exercise' through the output test feature in 01 - engine.
fordfan is offline
Old 29-07-2008, 15:13   #3
Members Car:
Smile Re: Fabia 1.4 16v mixture too lean
Hi Fordfan,
Thanks for quick reply.
Just been out to the car for code, and this sounds wierd, but there are now no codes being reported despite engine warning light still on.
Here is sequence of events:
Saturday cleaned vgr pipe, cleared codes, all OK.
Later Saturday engine warning back on! checked codes, this time lean mixture as query here, left code.
Monday decided to check code and cleared it, later warning light back on.
Tuesday input details here.
Now I've cleared codes again, despite no codes being reported, warning light now out. Could it be the adaptation of the ecu adjusting the mixture over a period of time after clean out and now back to normal?
I'll monitor things and report back any more probs.
Johnr990 is offline
Old 29-07-2008, 16:13   #4
Theresias's Avatar
Members Car: MY 2007
Post a complete scan please, we've seen enough cases like that by now but to get you a real answer it requires some more data from the car. Usually this thing is a software glitch in the ECU, multiple possible reasons for that though.
Sebastian
Theresias is offline
Old 29-07-2008, 16:18   #5
Members Car:
Hi Sebastian,
How do I post a complete scan?
I have the shareware version of VAG com.
Cheers
Johnr990 is offline
Old 29-07-2008, 16:22   #6
Theresias's Avatar
Then you can't post a complete scan, but you can still use...
Select > 01 - Engine > Fault Codes - 02 > Copy/Save Codes
...and the post the content here.
Sebastian
The Following User Says Thank You to Theresias For This Useful Post:
Johnr990 (29-07-2008)
Old 29-07-2008, 16:32   #7
Members Car:
Thanks Sebastian, in future I will post all data from VAG com
Johnr990 is offline
Similar Threads
Boost and mixture in MaxiDot :) duckstardeluxe Octavia II 15 04-07-2008 14:20
Lean Mean Clean Machine chris_1d Superb 25 11-12-2007 13:57
additive mixture to low 1.8t Superb 2 23-11-2007 21:47
Runing rich & lean Gwilo Diagnostics & VAG-COM 7 19-05-2005 21:03
