40,611 Members 1,518,087 Posts
Fabia 1.4 MPI Engine management light?
This is a discussion on Fabia 1.4 MPI Engine management light? within the Diagnostics & VAG-COM forums, part of the General Motoring Discussions category; I've just been looking at a Fabia which is showing its EML. Two faults were shown, one from the engine: ...
Old 27-11-2007, 00:19   #1
VRSPhil's Avatar
Members Car: Passat Sport TDi
Images: 1
P0441 Evaporative Emission Control System Incorrect Purge Flow
and also this:
Address 08: Auto HVAC Labels: Redir Fail!
Part No: 6Y0 820 045
Component: Klimaanlage X0760
1 Fault Found:
00818 - Sensor for Evaporator Outlet Temperature (G263)
30-10 - Open or Short to Plus - Intermittent
Any ideas?
Thanks.
'54 Passat PD130 Sport... 55mpg
Octavia vRS WRC - Gone but not forgotten!
VRSPhil is offline
Old 27-11-2007, 01:05   #2
VRSPhil's Avatar
Images: 1
Re: Fabia 1.4 MPI Engine management light?
Think I've worked out that the second fault is related to the A/C, so probably not relevant to the EML.
VRSPhil is offline
Old 27-11-2007, 09:55   #3
Members Car:
This should help mate. I would check all the pipe work to the throttle body first as they seem to be the most common issue from my experience.
16825/P0441/001089 - Ross-Tech Wiki
Longman is offline
Old 27-11-2007, 10:03   #4
ASZ Eternal
ap0gee's Avatar
Members Car: Black Magic Fabia vRS
...and as luck would have it, here's a technical guide I did for the evaporator temperature sensor (with some help, it must be said!), which should cover the second fault - although like you say it wouldn't have caused the EML light to come on...
I'm 99.9% sure that's what the second fault is about, but there's a brief description of the symptoms in the TG. It's worth doing this job yourself unless your car's still in warranty as otherwise it's an expensive job for a dealer (although I gather they have to do it for a fixed price set by Skoda, which they're not happy about as the 'proper' way is to take the dash out! )
Hope this helps
ap0gee is offline
Similar Threads
Got here because of the Engine Management Light... sulebust INTRODUCE YOURSELF! First time visitors, say hello here. 2 23-10-2007 13:37
Engine Management Light nickg Fabia I 3 18-10-2007 10:37
Engine Management light has come on... Bravo2zero_sps Octavia I 10 23-03-2007 08:51
Fabia engine management light. crismusic Fabia I 0 28-12-2006 11:11
engine management light on jamestay1 Fabia I 4 01-01-2006 16:51
