40,614 Members 1,518,181 Posts
Fabia 1 Key Coding
This is a discussion on Fabia 1 Key Coding within the Diagnostics & VAG-COM forums, part of the General Motoring Discussions category; Hi All, Having issues with VAG-COM accessing the Central Convenience controller (46) to code a new remote. In "Adaptation", channel ...
Old 25-03-2008, 13:40   #1
Fabia 1 Key Coding
Hi All,
Having issues with VAG-COM accessing the Central Convenience controller (46) to code a new remote. In "Adaptation", channel 01 indicates that the stored number of remotes was 1. This is despite there being two keys from new. When we try to increase the value from 1 to 2 the "Test" button dissappears i.e we can't add a remote.
Strangely, the key coding went fine as we have the 4-digit code for the car.
Do Skoda have a different way of coding remotes?
Yours, Perplexed!
enigmaci is offline
Old 25-03-2008, 14:03   #2
Uwe@Ross-Tech's Avatar
Members Car:
Re: Fabia 1 Key Coding
Post the complete part number from your Convenience Module please. VAG-COM shows it as "VAG Number" when you access the module.
-Uwe-
Uwe@Ross-Tech is offline
The Following User Says Thank You to Uwe@Ross-Tech For This Useful Post:
enigmaci (27-03-2008)
Old 26-03-2008, 20:56   #3
Jelly Mould
fordfan's Avatar
Members Car: Ford
Go into channel 00 first and erase all the remotes, then into channel 01 and adapt the number of remotes that you require.
fordfan is offline
The Following User Says Thank You to fordfan For This Useful Post:
Old 26-03-2008, 21:00   #4
Partner
Lummox's Avatar
Images: 2
Yup, you need to clear them before you can program more
www.unit18.co.uk
Lummox is offline
Old 26-03-2008, 22:44   #5
Mongreller
devonutopia's Avatar
Members Car: Skoda Fabia Mongrel
Images: 5
Do you think when I (eventually ) attempt to plug in my vRS convenience module into my car I will also need to go through the process of wiping off keys and reprogramming them? Done it once quite a while ago with help of Monsieur Lummox. August 2005 IIRC.
devonutopia is offline
Old 26-03-2008, 23:01   #6
Jelly Mould
fordfan's Avatar
Members Car: Ford
I would have thought so, as it would have originally been adapted for different key remotes. It's very simple to do.
fordfan is offline
Old 27-03-2008, 13:33   #7
Thanks all for your advice. Indeed, a clear-out of channel 00, followed by following coding procedure in channel 01 did the trick in less than a minute! Thanks, Uwe for providing such a versatile and user-friendly tool.
Regarding convenience module, yes as above.
Regards,
Richard
enigmaci is offline
Old 27-03-2008, 20:37   #8
Mongreller
Images: 5
And I assume once the vRS ECU is in, there's no other serious issues to worry about, besides recoding my ignition key/s?
I have to admit, I am very surprised my "vRS" current state of running actually worked fine with the current "pd100" convenience module in my car. Keys coded OK when I did it, so doubt it is an issue.
Thank f*** I have the 4 digit code for my car though. Else I'd be having a right 'mare.
Similar Threads
Help coding new fabia vrs dashpod jmd Diagnostics & VAG-COM 17 14-03-2008 22:51
Key coding immob Dox Octavia I 2 01-07-2007 10:17
Key fob / immo coding questions dackjaniels Diagnostics & VAG-COM 41 19-01-2007 09:10
Remote Key Re-coding greg2302 Maintenance & Performance 0 03-08-2004 09:51
Key Re-coding cisdsmit Maintenance & Performance 4 11-09-2003 13:22
