This is a discussion on fabia power steering dash light on within the Diagnostics & VAG-COM forums, part of the General Motoring Discussions category; Hi Catson here can any one help me with my 2004 fabia 1.9tdi i have replaced the power steering electric ...
| Briskodian | fabia power steering dash light on Hi Catson here can any one help me with my 2004 fabia 1.9tdi i have replaced the power steering electric motor in car ,steering working fine but light on in dash went and got iT put on a bosch software lap top ,problem came up on computor as followS O51D CONTROL UNIT FOR POWER STEERING BLOCKED/POWER FAILURE can someone tell me please what and were this can be found to fix as i also have a 2003 fabia with possible the same problem PLEASE PLEASE SOMEONE HELP ME . |
| The Following User Says Thank You to catson For This Useful Post: | laurie (07-06-2007) |
| Briskodian Join Date: Apr 2006 Location: Mid Germany
Members Car: MY 2007 Thanks: 1
| Re: fabia power steering dash light on Bosch sucks for reading fault codes on VAG models, besides that you are not posting the complete data - the fault type is missing and the Bosch text isn't accurate. So either double check for the complete fault code data or read the stuff with a specific tool like VAG-COM, then we might be able to give you detailed instructions to fix that.
__________________ Sebastian |
Members Car: Fiat Panda Thanks: 16
| Re: fabia power steering dash light on Check the voltage across the terminals of the battery (with and without the engine running) ![]() Chris
| Briskodian | Re: fabia power steering dash light on still canot get light out ,here what happened car is 2004 1.9 Tdi was damaged on front righthand wing, bumper,slight chassis leg airbags deployed, I replaced airbags repaired car power steering motor was died so got a replacement from a skoda which had been burnt in inside of car, steering works ok but light on in dash have still the same trouble with another fabia do you have any ideas what does the cicruit board box above pedals about 6 ins square do would there be a problem there NEED HELP AS 2 FABIA,S HAVE THIS PROBLEM EVEN COULD I HAVE A PHONE NUMBER SO AS I COULD TALK . HELP CATSON |
