This is a discussion on Fault 17608 found on 1.8T within the Diagnostics & VAG-COM forums, part of the General Motoring Discussions category; Hi Can anyone help with the following fault I found on my 2001 Octavia 1.8T, as if needs some work ...
| Briskodian Join Date: Jan 2003 Location: Rochdale
Members Car: Fabia vRS Thanks: 0
| Fault 17608 found on 1.8T Hi Can anyone help with the following fault I found on my 2001 Octavia 1.8T, as if needs some work I'd rather have it done before the warranty runs out? Address 01: Engine Controller: 06A 906 032 HJ 1 Fault found 17608- Boost Pressure Control Valve (N249): Mechanical Malfunction p1200-35-00 I take it that it's not the DV Thanks |
| Briskodian Join Date: Nov 2002 Location: Kirriemuir
| Just checked on Autodata for fault code and to check if the Boost pressure is controlled by the turbo (as it is on the diesel engine) but this code is missing??? jumps from 17607 to 17609 and P1199 to P1201. If you know someone with VAG Com you can check the boost pressure against the demanded boost in the data readings to check whether its overboosting. I had a boost problem with my diesel and had to get a new Turbo (eek!) so better get it checked while under warranty. Sorry can't be more help.
__________________ Skoda Superb Comfort 1.9TDi 130, Superb Elegance 2.0TDi 140 ) |
| Briskodian | SJL, Take a look at this post.. http://www.briskoda.net/forums/showp...54&postcount=5 Could be the DV it seems. |
| Briskodian Join Date: Oct 2002 Location: J5 M61
Members Car: Mini Breadvan Thanks: 0
| I had this.. along with 17705.. is basically a boost leak `somewhere`.. get the dealer to do pressure tests etc. On mine was a pipe under the back of the sump. Feel free to search for posts by me with 17608 and 17705.
__________________ Ian __________________ Nice to be important, but more important to be nice... |
| Just a follow up note The car has been in for the fault to be sorted, yesterday, and the following were fitted:- TURBO RECIRCULATION VALVE (? N249) SECONDARY AIR VALVE (? N112) I've not had it on VAG-COM yet, but the car seems to pull more smoothly and feels nippier, or it might just be me!! Thanks for the pointers |
| Fault codes 17705 & 17545 | GAFF | Octavia I | 108 | 18-08-2008 15:07 |
| ECU Explorer | AwesomeAPR | Awesome GTI | 14 | 02-12-2004 12:01 |
| Hard Starting Problem With 1.8t | Turbo_Boss | Maintenance & Performance | 19 | 25-01-2004 17:17 |
| Googlisms! | Tavia4x4 | Off Topic and Chit Chat | 46 | 30-10-2003 17:49 |
| How do the 4 versions of the 1.8T engine fitted to the UK Octavia differ? | DGW | Maintenance & Performance | 1 | 15-08-2003 12:30 |
