This is a discussion on Fault analysis please. within the Diagnostics & VAG-COM forums, part of the General Motoring Discussions category; I'm hoping someone can shed some light on my errors I got today. The glowplug relay one I know what's ...
| Freeeeeedom Join Date: Nov 2007 Location: Glasgow
Members Car: Fabia vRS Thanks: 35
| Fault analysis please. I'm hoping someone can shed some light on my errors I got today. The glowplug relay one I know what's up with it. My main concern is the MABS one. Thanks VAG-COM Version: Release 311.2-N Chassis Type: 6Y - Skoda Fabia Scan: 01,02,03,08,09,15,17,19,37,44,46,56,69 Address 01 ------------------------------------------------------- Controller: 038 906 019 NF Component: 1,9l R4 EDC G000SG 5839 Coding: 00102 Shop #: WSC 13765 TMBWU46YX44144365 SKZ7Z0D2530064 2 Faults Found: 18027 - Glow Plug Relay (J52): Open or Short to Ground P1619 - 35-10 - - - Intermittent 17675 - Pump-Jet Valve: Cylinder 3 (N242): Regulation Range Exceeded P1267 - 35-10 - - - Intermittent Readiness: N/A Address 03 ------------------------------------------------------- Controller: 6Q0 907 379 S Component: MABS 8.0 front H03 0001 Coding: 0000008 Shop #: WSC 13765 1 Fault Found: 18265 - Load Signal: Error Message from ECU P1857 - 000 - - - Intermittent Address 08 ------------------------------------------------------- Controller: 6Y0 820 045 Component: Klimaanlage X0840 No fault code found. Address 09 ------------------------------------------------------- Controller: 6Q1 937 049 D Component: 0000 BN-SG. 1S34 Coding: 25754 Shop #: WSC 13765 No fault code found. Skipping Address 15-Airbags Address 17 ------------------------------------------------------- Controller: 6Y0 920 970 S Component: KOMBI+WEGFAHRSP VDO V07 Coding: 28401 Shop #: WSC 13765 TMBWU46YX44144365 SKZ7Z0D2530064 No fault code found. Address 19 ------------------------------------------------------- Controller: 6N0 909 901 Component: 0037 GATEWAY CAN 1S34 Coding: 00014 Shop #: WSC 13765 No fault code found. Address 44 ------------------------------------------------------- Controller: 6Q0 423 156 AB Component: LenkhilfeTRW V270 Coding: 10150 Shop #: WSC 13765 No fault code found. Address 46 ------------------------------------------------------- Controller: 6Q0 959 433 E Component: 33 Komfortgerát 0002 Coding: 00066 Shop #: WSC 13765 No fault code found. End ------------------------------------------------------- |
| Briskodian Join Date: Jun 2007 Location: Brecon/ Cardiff
Members Car: 04 Fabia vRS (180/300) Thanks: 28
| Re: Fault analysis please. I got a pump jet valve fault the other day do you have a tuning box or remap on the car?
__________________ '04 Fabia VRS - P-Torque STG1, 312mm Brakes, Whiteline RARB, SEAT Sport Strut Brace, Pipercross Panel Filter & PD160 Intake, Pioneer and Infinity ICE, Custom exhaust system w/ de-cat, CCV Bypass w/ Catch Can, Swoosh Gauges, Window Tints |
Members Car: Skoda Fabia Mongrel Images: 5 Thanks: 79
| Re: Fault analysis please. the glow plug fault code is classic symptom of a broken wire, or a plug which has come off. I would check all the 4 plugs for the glowplugs, and then check the loom as well. If nothing obvious, clear the fault and re-check after a drive. If there is a real problem with the wiring, it should come right back.
__________________ Jason - Only a Skoda. Custom Fabia Bonnet Lifter Kits - £45! Click Me. BRISKODA CLUBSTAND @ Castle Combe! 25/04/09! Track session too! Click me! See the mongrel's 260bhp Dyno Video! |
| | #4 | |
| Re: Fault analysis please. Quote:
Yes I have a remap. | |
| Breatpoint analysis using excel | gadgetman | The Tech Shed | 2 | 22-07-2008 14:35 |
| Woman - A Mathematical Analysis | andy2407 | Off Topic and Chit Chat | 6 | 04-07-2008 00:03 |
| Power steering fault - fault code 01288 - is this the normal plastic sensor fault? | mgskoda | Diagnostics & VAG-COM | 6 | 05-11-2007 19:31 |
| Social Work Analysis | westerdam2 | Off Topic and Chit Chat | 0 | 11-07-2006 20:08 |
| Mood analysis test | roo | Off Topic and Chit Chat | 8 | 24-02-2005 00:13 |
