40,611 Members 1,518,116 Posts
Fault code 16502?
This is a discussion on Fault code 16502? within the Diagnostics & VAG-COM forums, part of the General Motoring Discussions category; My daughter has a fabia 1.4MPI Registered March 2002. With a warning light on the 'engine management' it read fault ...
Old 04-08-2008, 19:29   #1
Members Car:
Question Fault code 16502?
With a warning light on the 'engine management' it read fault code 16502 with 01/01 on the second line of the scanner.
In the list provided this means: Engine coolant temperature circuit-High input (Low temp)
Can anyone translate that into english for me?? Thanks in advance
alechi is offline
Old 04-08-2008, 20:33   #2
Jelly Mould
fordfan's Avatar
Members Car: Ford
Re: Fault code 16502?
16502
P0118
Engine Coolant Temp.Circ High Input
Replace the engine coolant temperature sensor, very easy to do on the mpi. Remove the old one first and have a look/feel around to make sure that the thermostat hasn't broken up. A sensor on its own is around £25 and a thermostat complete with sensor around £40 all + VAT. You don't want to buy a sensor to find out that you need a thermostat.
fordfan is offline
Old 06-08-2008, 08:48   #3
Members Car:
I'll give that a go.
Thanks for the advice
Alec
alechi is offline
Similar Threads
fault code help dougie vrs Octavia I 2 31-07-2008 09:25
Fault code help Please markyspark Diagnostics & VAG-COM 1 11-03-2008 02:12
Power steering fault - fault code 01288 - is this the normal plastic sensor fault? mgskoda Diagnostics & VAG-COM 6 05-11-2007 19:31
Help with Fault Code GAFF Maintenance & Performance 5 27-07-2007 16:46
Fault Code davidi Octavia I 1 27-09-2005 21:31
