39,433 Members 1,488,760 Posts
Fault Code Found Fabia VRS
This is a discussion on Fault Code Found Fabia VRS within the Diagnostics & VAG-COM forums, part of the General Motoring Discussions category; Hi just did a scan on my VAG COM v3.01 Came up with this Address 09 Controller 6Q1 937 049 ...
Old 06-04-2008, 14:47   #1
ultra_joel88's Avatar
Members Car: 04 Fabia vRS (180/300)
Came up with this
Address 09
Controller 6Q1 937 049 D
Component 0000 BN-SG. 1S34
Coding 25738
Shop#. WSC 13765
1 Fault Found:
01598 - Drive Battery Voltage
07-00 Signal too Low.
I have a dragon tuning box fitted, would this cause it?
'04 Fabia VRS - P-Torque STG1, 312mm Brakes, Whiteline RARB, SEAT Sport Strut Brace, Pipercross Panel Filter & PD160 Intake, Pioneer and Infinity ICE, Custom exhaust system w/ de-cat, CCV Bypass w/ Catch Can, Boost + Volt Gauge, Window Tints
ultra_joel88 is offline
Old 06-04-2008, 14:54   #2
Mongreller
devonutopia's Avatar
Members Car: Skoda Fabia Mongrel
Images: 5
Re: Fault Code Found Fabia VRS
Nah - Sounds to me like the car may have failed to start on the button like it usually does and a sensor somewhere thought it was getting lower voltage than usual. I would just clear it if the car is running ok.
Jason - Only a Skoda.
Custom Fabia Bonnet Lifter Kits - £45! Click Me.
Cheesy bonnet lifter video to "raise me up" http://www.youtube.com/watch?v=hMnGECEi5Oc
See the mongrel's 260bhp Dyno Video!
devonutopia is offline
Old 06-04-2008, 14:58   #3
The other day I did the "cage" (application of silicon grease to electrical connections) mod on the MAF and a couple of other sensors, that could be throwing it off?
Yah the cars running fine.
Old 06-04-2008, 15:42   #4
ECUless
fordfan's Avatar
Members Car:
Often see that code when the car has had a flat battery.
fordfan is offline
Old 06-04-2008, 17:03   #5
The battery is fine though....
Old 08-04-2008, 18:33   #6
Cleared it and scanned again
Came up with the same but this time with "Intermittent" at the end....
Similar Threads
vRS TD Fault code help mr.nik Octavia II 2 08-03-2008 13:21
Power steering fault - fault code 01288 - is this the normal plastic sensor fault? mgskoda Diagnostics & VAG-COM 6 05-11-2007 19:31
octavia vrs fault code millsyman22 Octavia I 0 10-10-2006 13:22
