Fault Codes on Octy vRS mk1
This is a discussion on Fault Codes on Octy vRS mk1 within the Diagnostics & VAG-COM forums, part of the General Motoring Discussions category; After spotting some oil on the driveway and nothing seemed to be out of the norm, mechanically, I decided to ...
Old 27-04-2008, 18:42   #1
bpm
Drink me!
bpm's Avatar
Default Fault Codes on Octy vRS mk1
After spotting some oil on the driveway and nothing seemed to be out of the norm, mechanically, I decided to take VSAG-COM out and give the car the quick once over...
2 Faults Found:
16804 - Catalyst System; Bank 1: Efficiency Below Threshold
P0420 - 35-00 - -
16712 - Knock Sensor 1 (G61): Signal too High
P0328 - 35-10 - - - Intermittent
Readiness: 0000 0000
I did clear the codes and they have not returned yet after an engine turn off then on again. I've yet to take it for a spin.
What should I look out for with the above faults? (What does the knock sensor do anyway?)
BPM
This is a website , NOT a mobile phone.
STP USNG TXT SPK
bpm is offline
Old 27-04-2008, 20:27   #2
DGW
BRISKODA Staff
DGW's Avatar
Default Re: Fault Codes on Octy vRS mk1
16804/P0420/001056 - Ross-Tech Wiki
16712/P0328/000808 - Ross-Tech Wiki
Denis
2007 Fabia vRS - CC, ESP and full leather trim by Seat Surgeons ...48.09 mpg...
DGW is online now
Old 27-04-2008, 20:45   #3
ECUless
fordfan's Avatar
The knock sensor senses vibrations from the engine, particularly vibrations caused by the fuel igniting before it's supposed to. If it senses a vibration it will send a signal to the ECU that will in turn retard the ignition timing, which will take the edge of the performance.
Fuel pre-ignition can be caused by the ignition timing being too advanced, an inferior quality fuel and not so much found theses days - excessive carbon build up in the combustion chambers, leading to a higher compression ratio and hot spots. I have known a 8 valve Fabia suffer from reduced performance caused by a rattling timing chain setting off the knock sensor.
fordfan is offline
The Following User Says Thank You to fordfan For This Useful Post:
bpm (27-04-2008)
Old 27-04-2008, 23:33   #4
bpm
Drink me!
bpm's Avatar
Thanks fordfan.
I was thinking I had a tankful of dodgy petrol recently, but the car was much more lively once a new tankful of petrol was put in. I think it's time to treat the car to a tankful of v-power to clean out the pipes!
BPM
STP USNG TXT SPK
bpm is offline
Old 21-05-2008, 00:56   #5
I have the same two codes show up at the same time. I can't figure out why they are on simulataneously.
dubaudiri is offline
