This is a discussion on Fault codes! within the Diagnostics & VAG-COM forums, part of the General Motoring Discussions category; Please help, a freind has a 2002 Audi A6 with the 1.9 TDI 130 BHP lump. It has started to ...
| Briskodian | Fault codes! Please help, a freind has a 2002 Audi A6 with the 1.9 TDI 130 BHP lump. It has started to intermitantly hesitate for a very breif moment when pulling away. It just won't pull away smoothly sometimes but most the time is fine. Did a fault code search and found the following: Could somebody shed some light of what this is actually trying to tell us. The car is factory standard. A6.JPG Thanks.
__________________ There's nothing like seeing feathers going in the opposite direction to the bird! ....................................... |
| Briskodian Join Date: Sep 2005 Location: Nottingham
Members Car: Octavia TDi Elegance Estate Thanks: 5
| Re: Fault codes! Errr don't think any of those relate to the engine... Probably... |
| The Following User Says Thank You to trundlenut For This Useful Post: | Octavia Vrs! (25-09-2008) |
| Partner Join Date: Sep 2003 Location: Newport Pagnell
Members Car: Mk2 Golf GTi 16v and building a 20VT MK2. Images: 2 Thanks: 29
| Re: Fault codes! Central door locking and radio issues, naff all to do with engine. |
| The Following User Says Thank You to Lummox For This Useful Post: | Octavia Vrs! (25-09-2008) |
| Briskodian | Re: Fault codes! That's what i thought - Thankyou. Any ideas what it could be? It's just as you accelerate at low revs it pulls then quickly cuts all power then pulls again. It's nothing to do with traction control ect. When you put the key in the ignition the fuel pump runs but sounds like it has air in it. He says it's done this since he's had the car (approx 2 years) but the fault has only started in the last month. It runs fine at high revs and cruising speeds. Bit baffled ![]() He has also put a fuel cleaner through it with no result. Cheers
| fault codes | big daveni | INTRODUCE YOURSELF! First time visitors, say hello here. | 4 | 13-11-2007 09:24 |
| Help on these fault codes. | VRSDale | Diagnostics & VAG-COM | 8 | 01-08-2007 18:33 |
| Help with fault codes | black vtr | Diagnostics & VAG-COM | 5 | 11-12-2006 22:40 |
| Help with some fault codes | istedman | Diagnostics & VAG-COM | 6 | 10-07-2004 00:04 |
