40,611 Members 1,518,121 Posts
Generic OBD2 Fault Codes.
This is a discussion on Generic OBD2 Fault Codes. within the Diagnostics & VAG-COM forums, part of the General Motoring Discussions category; (Repost) With some exceptions, the OBD II warning lamp will go out if a problem does not recur after 40 ...
Old 23-12-2007, 14:44   #1
Psyzygy's Avatar
Location: Behind the wheel of a small automobile somewhere in the East Midlands
(Repost)
With some exceptions, the OBD II warning lamp will go out if a problem does not recur after 40 drive cycles. A drive cycle means starting a cold engine and driving it long enough to reach operating temperature.
The
TROUBLE CODES that are required by law on all OBD II systems are "generic" in the sense that all vehicle manufacturers use the same common code list and the same 16-pin diagnostic connector. Thus, a P0302 misfire code on a Nissan means the same thing on a Honda, Toyota or Mercedes-Benz. But each vehicle manufacturer also has the freedom to add their own "enhanced" codes to provide even more detailed information about various faults.
Enhanced codes (P1 codes), which are special OEM codes for specific vehicle applications, provide additional information and often cover non-emission related failures that occur outside the engine control system. These include ABS codes, HVAC codes, air bag codes and other body and electrical codes.
The second character in an OBD II will be a zero if it is a generic code, or a "1" if it is a dealer enhanced code (specific to that particular vehicle application).
The third character in the code identifies the system where the fault occurred. Numbers 1 and 2 are for fuel or air metering problems, 3 is for ignition problems or engine misfire, 4 is for auxiliary emission controls, 5 relates to idle speed control problems, 6 is for computer or output circuit faults, and 7 and 8 relate to transmission problems.
TROUBLE CODES For a more detailed explanation of the longer code numbers.
Yam FS1E, Yam RD 200, ancient Mk 1 Mini 850, Ford Zephyr, Mint Mk1 Cortina 1500 Super, 1500 FD Victor o/d, Triumph Toledo, 1800 Marina deluxe, 2.0 Montego estate, Datsun Sunny 120, Mazda 626, two 1300 Astra estates, Mk 2 1050 Polo - all gone to meet their maker. Piaggio Sfera, 95 Felicia 1.3 GLXi SPi. 136B (I think that's lt )
Psyzygy is offline
The Following User Says Thank You to Psyzygy For This Useful Post:
Ned (24-02-2008)
Similar Threads
Generic OBD2 Fault Codes. Psyzygy Reference Materials 0 19-12-2007 00:45
fault codes big daveni INTRODUCE YOURSELF! First time visitors, say hello here. 4 13-11-2007 09:24
Help with fault codes fluffy01016 Diagnostics & VAG-COM 7 25-02-2006 16:44
5 fault codes!!! Mr Peas Octavia I 10 26-07-2005 21:29
