This is a discussion on God damn k-line within the Diagnostics & VAG-COM forums, part of the General Motoring Discussions category; Got hold of a vag com cable the other day and was toying with the idea of having a go ...
| | #1 | |
| Briskodian | K-line issues? Got hold of a vag com cable the other day and was toying with the idea of having a go this weekend I figured I'd check that I'd installed my stereo correctly with the 12v k-line issue you can get. Now i was 99% certain I'd done this correctly and didn't fancy removing my stereo for a 2nd time! I went over to read up on ross tech about the k-line issue and now I'm a tad baffled... not sure if its me being a voltmeter dummy or if the k-line is actually sorted. I followed the instructions below... Quote:
Getting hold of some resistors isn't too easy in my area and everywhere will be closing up today ![]() So my question is do you think i've used the wrong settings on the volt meter? I don't think i have which makes me even more curious abotu the radio install. Am i safe in presuming that the half decent ebay cables don't come with protection against the surge if it was shorted? edit - Well as a work around in the time being i figured I'd disconnect the stereo completely which only meant taking the glove box out and disconnecting the iso connections. I checked what i believed to be the k wire as per the ross tech documentation. The grey and white wire/pin 3 of the black half of the car connections didn't make any contact with the head unit harness anyway. I figured I'd then take the voltages again with the head unit detached and the ignition on and they were exactly the same as before when the head unit was connected so i presume I'm good to go? Anything i haven't thought of? Last edited by Funkoid; 20-09-2008 at 16:21. | |
| Briskodian | Re: God damn k-line edit - Well as a work around in the time being i figured I'd disconnect the stereo completely which only meant taking the glove box out and disconnecting the iso connections. I checked what i believed to be the k wire as per the ross tech documentation. The grey and white wire/pin 3 of the black half of the car connections didn't make any contact with the head unit harness anyway. I figured I'd then take the voltages again with the head unit detached and the ignition on and they were exactly the same as before when the head unit was connected so i presume I'm good to go? Anything i haven't thought of? |
| Briskodian Join Date: Sep 2006 Location: Walsall
Members Car: Leon TDI DSG or Lupo 16v Sport Thanks: 115
| Re: God damn k-line How about pulling the radio fuse temporarily?
__________________ -- Chris ---------------------------------------------------- The Devil may care, but I don't mind. |
| Briskodian | Re: God damn k-line Well... with the voltages being the same and my gear only costing a tenner (as long as it didn't blow my hu :p) .... i went for it. All is working okay. Am still a little concerned with the voltage hitting 11v which is higher than stated on ross techs site but everything is working fine...... and more to the point the k-line isn't connected, this was confirmed by vag-com too! |
| Re: God damn k-line The thing is is that a high-mpedance multimeter will read near 12v even with a current-,limited source. I wouldn't worry, since it works.
| damn... | andypandypoos | The Tech Shed | 20 | 08-03-2008 21:53 |
| God damn OCty Mk1 cd changer | Angry Dog | ICE, Security and Insurance | 6 | 15-01-2008 11:25 |
| God Damn Phones!!!! | Angry Dog | Off Topic and Chit Chat | 2 | 21-12-2007 19:18 |
| God Damn Stereo! | beeftech | ICE, Security and Insurance | 8 | 03-05-2005 22:51 |
| Thank God! | rich1068 | General Car Chat | 9 | 19-05-2003 11:26 |
