This is a discussion on Help - cleared all keys from immobiliser within the Diagnostics & VAG-COM forums, part of the General Motoring Discussions category; If anyone could help me with this I would be very grateful. I was trying to code a new key ...
| Briskodian Join Date: Jul 2006 Location: Bradford
Members Car: Fabia 1.9 SDI/Fabia 1.9 Tdi Est. Thanks: 5
| Help - cleared all keys from immobiliser If anyone could help me with this I would be very grateful. I was trying to code a new key to my '06 FABIA estate TDi using VRU STU's excellent instructions ( these worked fine on my other car SDi ). I have managed to login and clear all the keys but can't get the keys to re-scan. When I checked for error code I get the following :- Address 01 Powertrain 18097 - Powertrain Data bus implausible message P1689 - 35-00 - - 17978 Engine start blocked by immobiliser P1570 -35 - 10 - - - Intermitent Address 09 01598 - Drive Battery Voltage 07-00 signal to Low Address 17 Instruments 01176 - Key 65 - 10 Unauthorised - intermittent 01179 Incorrect Key Programming 35 - 00 - - [This is abridged all other units work] [apologies for any mistakes but re-keying rather than pasting] Is it something as simple as the battery voltage is too low ? Or is the antenna for the key not working correctly ? Thanks in advance
__________________ FABIA 1.9SDi 100,000 FABIA 1.9TDI 17,100 |
| Briskodian Join Date: Sep 2006 Location: Walsall
Members Car: Leon TDI DSG or Lupo 16v Sport Thanks: 115
| Re: Help - cleared all keys from immobiliser I'd try charging the battery first and see if it works then. |
Members Car: Audi S3 Thanks: 195
| Re: Help - cleared all keys from immobiliser Does the battery one clear off? You normally see that if the battery has been disconnected.
__________________ Stu Stu's Websites - http://www.fabia-vrs.com & http://www.octavia-vrs.com Stu's Car - 2008 Audi S3 - Ibis White, Black Optics Pack, Privacy Glass, Auto Bi Xenon Headlights, Rain Sensing Wipers, Bose Sound System, Ipod Prep, GSM Phone Prep, Flat Bottom Multi Function Steering Wheel, Electric Folding Mirrors, Acoustic Parking, Cruise Control, Interior Light Pack, Non Smokers Pack. SWMBO's Car - 2008 Seat LEON TDi Stylance, Black Magic, Sports Pack, Rear Parking Sensors. Something for Weekend - A Patio |
| The Following User Says Thank You to VRStu For This Useful Post: | garethw (02-11-2007) |
| Jelly Mould | Re: Help - cleared all keys from immobiliser With ignition on, first of all go into 17and clear any fault codes, then log in (11) with your code and remember to prefix it with 0, adaptation (10) and channel 21, enter in 2 keys, test, save, OK and get back to the modules listing screen and put the other key in the ignition and turn it on - then hopefully both keys will be programmed. |
| The Following User Says Thank You to fordfan For This Useful Post: | garethw (02-11-2007) |
| Re: Help - cleared all keys from immobiliser OK, I have recharged the battery, it reads 12.4 V on the central load controller. Tried clearing the fault codes on all the units but the best I can do is either 1 or 2 keys working but still with the immobiliser light on i.e. engine starts and runs but imobiliser light still flashes. I seem to be stuck with the fault code on the instument cluster. When you are trying to pair your keys the imobiliser symbol just flashes. I am aiming for 3 keys is this not feasible It drives at the moment so perhaps Iwill have to take it to the dealears.
| Partner Join Date: Sep 2003 Location: Newport Pagnell
Members Car: Mk2 Golf GTi 16v and building a 20VT MK2. Images: 2 Thanks: 29
| Re: Help - cleared all keys from immobiliser IIRC you can program up to 5 sets of keys, Something has got to be wrong with the way your coding them. |
| The Following User Says Thank You to Lummox For This Useful Post: | garethw (02-11-2007) |
| Re: Help - cleared all keys from immobiliser Or that the key isn't suitable for the car - is it from eBay?
| OK, After reading through the advice more carefully. I found out my finger trouble . I was taking the first key out and putting it back in. At which point the instrument cluster records that as 1st and 2nd keys, the next key gets accepted but of course you now throw an error code. THANKS GUYS.
| Re: Help - cleared all keys from immobiliser Good result then.
| | #10 |
| Briskodian Join Date: Apr 2006 Location: Mid Germany
Members Car: MY 2007 Thanks: 1
| Re: Help - cleared all keys from immobiliser Just for future reference, usually the maximum number of keys (immobilizer) either 4 or 8 - 8 is most common for every more or less current model. In terms of remotes (central locking) the magic number is 4 while auxiliary heating remotes it's usually 3 or 4 depending on the individual system.
__________________ Sebastian |
| Inboxes are there to be cleared... | anonymouse | Off Topic and Chit Chat | 12 | 27-08-2007 12:38 |
| 17705 Fault - Cleared in VAG, Will it come back? | morgan349 | Octavia I | 9 | 25-05-2007 08:14 |
| Porsche cleared to buy controlling stake in VW | Stuart_J | General Car Chat | 11 | 13-07-2006 14:02 |
| Can you pay to have a cheque cleared quicker? | Goochie | The Roadside Hotel | 13 | 22-02-2006 13:18 |
| immobiliser | Daddy2Coull | Octavia I | 2 | 14-11-2005 23:33 |
