This is a discussion on Help coding new fabia vrs dashpod within the Diagnostics & VAG-COM forums, part of the General Motoring Discussions category; Received a new maxidot dash pod from VRStu. I'm having problems getting the dash to work properly. Stu has been ...
| Briskodian | Help coding new fabia vrs dashpod Received a new maxidot dash pod from VRStu. I'm having problems getting the dash to work properly. Stu has been extremely helpful so far and has spent a lot of time trying to get it working but so far we are having no luck. The maxidot portion of the dash works fine. The problems I am currently having are, speedo does not work at all, revs are ~300 behind what they should be, fuel guage is above what it should be and moves wildy to empty when I turn right. Miles, mpg etc don't work but I am atm assuming this is something to do with the fact speedo etc don't work. New dash pod has the same soft code and adaptation values as the old one. I am receiving one error about intermittent one wire can bus operation but this doesn't always show up. I have followed the ross-tech guides exactly and the car will drive with the dash in, just not working properly. Not even sure if this is the correct section for this but if anybody has any ideas i'd be grateful for the help. |
| Briskodian | Re: Help coding new fabia vrs dashpod I'm interested it getting hold of a maxi dot display for my Fabia VRS too. Have you got the problem fixed yet? So aswell as installing the maxidot, you have to reprogram and reconnect some elements of the new face plate am I right?? |
Members Car: Audi S3 Thanks: 195
| Re: Help coding new fabia vrs dashpod I's pretty much a plug in job save for coding the immobilisor and service intervals however we don't seem to be able to get the Speedo to work, everything else seems ok. I have seen a Fabia Classic in CZ with one fitted and working but as yet we've drawn a blank on the vRS over here.
__________________ Stu Stu's Websites - http://www.fabia-vrs.com & http://www.octavia-vrs.com Stu's Car - 2008 Audi S3 - Ibis White, Black Optics Pack, Privacy Glass, Auto Bi Xenon Headlights, Rain Sensing Wipers, Bose Sound System, Ipod Prep, GSM Phone Prep, Flat Bottom Multi Function Steering Wheel, Electric Folding Mirrors, Acoustic Parking, Cruise Control, Interior Light Pack, Non Smokers Pack. SWMBO's Car - 2008 Seat LEON TDi Stylance, Black Magic, Sports Pack, Rear Parking Sensors. Something for Weekend - A Patio |
| Briskodian | Re: Help coding new fabia vrs dashpod Yip we have as yet had no luck. If we can't find out soonish and you fancy having a go at one you can have mine. Sure its just some coding somewhere though as everything works fine when trying the output tests on vagcom so the signal can definitely be sent to it. |
| | #5 | |
| Briskodian | Re: Help coding new fabia vrs dashpod Quote:
Do you think the issue could be with a faulty fascia product? | |
| Briskodian | Re: Help coding new fabia vrs dashpod Stu has just been speaking to me about this, he has managed to find an article about the speed issue. The dash pods come from factory set to fit cars without ABS. Cars without ABS get speed signal from the gearbox, the vrs gets it from the ABS sensors. There is a procedure using VAS to correct this but i'm not sure if it is even possible on vagcom. Guided Fault Finding ↵ • Function / Component Selection ↵ • Select function or component ↵ • Body ↵ • Electrical equipments ↵ • Dash panel insert ↵ • Electrical components ↵G-21 – Speedometer Is what I have to do. Anyone know if the equivalent can be done on vagcom? |
Members Car: Ford Escort 1.6LX + Fab Estate Thanks: 48
| Re: Help coding new fabia vrs dashpod Worth asking the VAGCOM software peeps perhaps, I am interested in this too as I a hoping to fit one of these to my rebuild ![]()
__________________ WW --->> Project Journal (pic links in first post there)Lummox'/Ross thread on Unit18 Automotive progress on my car: here |
Members Car: '97R BMW 328i Saloon Thanks: 728
| Re: Help coding new fabia vrs dashpod Sounds promising jmd. Anyone got a pukka Vagcom and able to contact Ross-tech?
| 2.0 FSI Sport. Join Date: May 2007 Location: oxon
Members Car: Octavia Mk2 FSI Sport Thanks: 13
| Re: Help coding new fabia vrs dashpod Is there many problems installing these to an octy 2? ive noticed my rev counter doesnt go into red till 6.5k where as the maxidot ones show red at a lower level ? |
| | #10 |
| Re: Help coding new fabia vrs dashpod Yep John has his own.
| | #11 |
| Re: Help coding new fabia vrs dashpod Takes about 10 minutes on an Octy II when you have the right equipment.
| | #12 | |
I just got my new '08 2,0 TDI Elegance Combi yesterday, and today my (brand new) RS TDI Maxidot dash insert arrived from Chech Republic. Does anybody know the steps nessecary to do the swap? I have access to VAG-COM, but the guy who has it has never tried a dash insert swap - except on a Golf IV. Greetings from Denmark Strandgaard | |
| | #13 |
| Briskodian Join Date: Apr 2006 Location: Mid Germany
Members Car: MY 2007 Thanks: 1
| Re: Help coding new fabia vrs dashpod Our WIKI covers the necessary steps for the OČ (IMMO4). Immobilizer IV Immobilizer Swapping (Instrument Cluster) - Ross-Tech Wiki
__________________ Sebastian |
| The Following User Says Thank You to Theresias For This Useful Post: | strandgaard (24-10-2007) |
| | #14 |
| Briskodian | Re: Help coding new fabia vrs dashpod That was followed to a T, the instructions do not work. Guided Fault Finding ↵ • Function / Component Selection ↵ • Select function or component ↵ • Body ↵ • Electrical equipments ↵ • Dash panel insert ↵ • Electrical components ↵G-21 – Speedometer They specific steps have to be done, unless there is another way to perform the same function? |
| | #15 | |
Greetings Jan Strandgaard | |
| | #16 |
| Briskodian Join Date: Feb 2008 Location: Scotland
Members Car: Furby RS 227 BHP Thanks: 0
| Re: Help coding new fabia vrs dashpod sorry to bring this from the dead but did this ever get resolved? as im hoping to do a maxidot retrofit in my vrs Adrian |
| | #17 |
| Broken :( Join Date: Oct 2004 Location: Around Manchester & Cheshire
Members Car: Skoda Fabia vRS Thanks: 472
| Re: Help coding new fabia vrs dashpod I'll get mine properly sorted one of these days, it's on my 'to do' list - promise! ![]() And I'll report back ![]() Most stuff is sorted on mine, but need fuel gauge calibrated and the speedo sorted. Both minor, unnecessary functions of the pod, I'm sure you'll agree ![]() Steve
__________________ Wardy's Fabia vRS ![]() xenons : sunroof : cruise : OEM+ ![]() "Racing is life. Anything before or after is just waiting." - Steve McQueen "If in doubt, flat out." - Colin McRae |
| | #18 | |
__________________ Run out of CASH | |
