This is a discussion on Help engine management light on within the Diagnostics & VAG-COM forums, part of the General Motoring Discussions category; Can anyone help as the engine management light has come on but seems to be performing as it should, no ...
| Briskodian | Help engine management light on Can anyone help as the engine management light has come on but seems to be performing as it should, no leaks, everything were it should be. Has anyone got VAG.com to match my octy VRS 2002 plate near me around mansfield area. ![]()
__________________ Feed more trees, so drive more |
| Briskodian Join Date: Jun 2007 Location: Notts
Members Car: Octavia VRS Thanks: 1
| Re: Help engine management light on Had the same issue as you today, theres a good independant garage in bulwell run by an ex skoda mechanic, im taking mine down tomorrow to have it scanned - typical the fault had to happen today, its booked in there for service on friday. Its DSB autocare 0115 977 1004 search on here has good reviews and ive always used for servicing. I live just outside mansfield and I have a cheapo vagcom lead Ive used with shareware vagcom, your welcome to use it but I have no laptop at the moment to hook upto the car |
| Briskodian | Re: Help engine management light on Cheers thanks for that mate, Ill try the bulwell place you named in your post as I am away bank holiday.I have a lead but it doesn't hook up with my car the software sees it ok. it's what I was given would like to buy one. ![]()
| Re: Help engine management light on cool, let us know how you get on, his fault reader came up airflow sensor - MAF as I suspected, he cleared the fault but they came back so it looks like a new MAF |
| Briskodian | Re: Help engine management light on under further investigation found that the hose clip from the intercooler had cracked and was loose so replaced and the light disappeared over night. so far!!! ![]()
| Engine Management Light | barebackmolly | Fabia I | 8 | 10-01-2008 21:04 |
| Got here because of the Engine Management Light... | sulebust | INTRODUCE YOURSELF! First time visitors, say hello here. | 2 | 23-10-2007 13:37 |
| Engine Management Light | nickg | Fabia I | 3 | 18-10-2007 10:37 |
| Engine management light | boarg | Fabia I | 12 | 26-07-2007 20:11 |
| engine management light | paul thomas | Fabia I | 15 | 16-01-2007 21:50 |
