39,433 Members 1,488,761 Posts
Help with lambda probe test
This is a discussion on Help with lambda probe test within the Diagnostics & VAG-COM forums, part of the General Motoring Discussions category; I have a Fabia 1.4 44kw AZE, 2001, 62000 miles. Since two months I am experiencing problems when idle. There ...
Old 30-09-2007, 16:16   #1
Members Car:
I have a Fabia 1.4 44kw AZE, 2001, 62000 miles. Since two months I am experiencing problems when idle. There is a little shaking and vibration. I was at the dealer, they found nothing and told me that is normal. I also went trough a number of threads in the forum, which also state the behavior is normal. But I just can't accept this. There was nothing like this before. I bought a cable to look for the problem. It looks to me that the lambda probe is not giving correct output. I also searched google and saw a number of lambda waveforms, but it looks like they are different for the different makes and models.
So, please, if somebody has experience with this, could you please look at the output (attached) and give me your opinion on the lambda probe condition.
The file contains the following groups:
3,1,Engine Speed,,Specification (manual): 800...900 RPM | Specification (automatic): 630...800 RPM
3,2,Intake manifold,pressure,Specification: 240...420 mbar
3,3,Throttle Drive,Angle Sensor 1,for EPC (G187) | Specification: 0.0...11.0 %
3,4,Ignition,Timing Angle,Specification: 0.0...10.0 °BDTC
33,1,Bank 1,Lambda Control,Specification: -10.0...+10.0 %
33,2,Bank 1 Voltage,of Oxygen Sensors,Specification: 0.00...1.00 V
33,3,NA
33,4,NA
32,1,Lambda (add.),Self-Adaptation,Specification: -10-+10%
32,2,Lambda (mult.),Self-Adaptation,Specification: -10-+10%
ililovski is offline
Old 30-09-2007, 17:00   #2
Cupra Bush King
Lummox's Avatar
Images: 2
Re: Help with lambda probe test
Really for those values to make any sense they need to be live data. We would need to see how the lambda probe is acting and if its output varies or if it is stuck on open loop.
www.unit18.co.uk
Lummox is offline
Old 30-09-2007, 19:53   #3
Members Car:
I have attached the live data (csv log) in the zip. I started the log at engine idle, then increased the engine speed trying to hold at about 2600 and dropped again to idle. Or you need something else?
Old 11-04-2008, 14:28   #4
Mickski's Avatar
Members Car: Seat Leon 1.8 20VT MRC
If you encount trouble with idle state, the MVB#32 field one should be check : additive fuel trim is used in idle state whereas multiplicative fuel trim is used in charge state.
Furthermore, you should give us the result of the Readiness.
Seat Leon 1.8 20VT MRC owner.
Mickski is offline
Similar Threads
Lambda probe connector problem ole166 Fabia I 4 23-08-2007 10:39
testing lambda probe andreiu RWD Skodas and others 3 06-07-2007 11:20
lambda probe woes fabiamad Fabia I 2 21-03-2006 10:10
Lambda Probe location steve101 Octavia I 3 16-08-2005 19:45
