This is a discussion on help my octavia fault 00561 within the Diagnostics & VAG-COM forums, part of the General Motoring Discussions category; car is runing rich and i get this fault so help me what to look at...
| Briskodian Join Date: Jan 2008
| car is runing rich and i get this fault so help me what to look at |
| ECUless Join Date: Mar 2005
| jes but everthing is ok and the fault is coming back |
| Hairy Yeti Join Date: Sep 2003 Location: Newport Pagnell
| Everything cant be ok if the fault is coming back. Take a look in MBV and see what the lambda probes are doing, what you want to find is the long term adaptive figure, its in a % and should be 0 +- 10% iirc. Whats the fuel pressure? In fact what engine are we talking about?
__________________ Unit 18 now open Servicing, repairs, modifications you name it we do it. Cupra console bushes at special price, PM for a very competitive quote. |
| 1,8t with 150 bhp AGU code where i can find out fuel pressure |
| Can you get into advanced measuring blocks and record actual and specified air flow during a drive?, if you can, compare them to see if the airflow sensor is OK. It may help to add some fuel injector cleaner and clean the throttle body and erase the learned values in the engine ECU. You'll need a fuel pressure gauge and a safe way of connecting it to the injector rail. Who said 'all you have to do is just plug in a computer and it'll tell you what's wrong.'? |
| maf is going to 120 g when i put gas pedal down to 6500 but on my car is lpg so when i drive i do not use fuel injetors i have tip and 3 inc exhaust |
| i think i foun problem my exhaust is leaking |
| Briskodian Join Date: Apr 2006 Location: Mid Germany
| Hmm... the WIKI says.. ![]() Code: Possible Causes
* Leaks in Intake Air System and/or Exhaust System
Possible Solutions
* Check Intake Air System and Exhaust System for Leaks
__________________ Sebastian |
| | #10 |
| jes the exhaust was problem weld s were bad |
