40,614 Members 1,518,180 Posts
Help Plz Vagcom Code Fault
This is a discussion on Help Plz Vagcom Code Fault within the Diagnostics & VAG-COM forums, part of the General Motoring Discussions category; i have a fault which vagcom is reading could anyone plz tell me in layman terms what the following means ...
Old 20-04-2008, 12:05   #1
Members Car:
i have a fault which vagcom is reading could anyone plz tell me in layman terms what the following means and how do i put it right :
1 Fault Found:
18043 - Powertrain Data Bus: Missing Message from A/C Controller
P1635 - 35-10 - - - Intermittent
stevelufc is offline
Old 20-04-2008, 12:11   #2
EddyH's Avatar
Members Car: Audi A6
Re: Help Plz Vagcom Code Fault
Don't plug vagcom again and you'll never see the fault again. Problem solved.
Seriously, with that sort of code unless you are noticing something not working then I wouldn't worry about it.
EddyH
Audi A6 Avant 2.7 TDI
Audi A3 2.0 TDI Sport
EddyH is offline
Old 20-04-2008, 12:12   #3
C+ à Paris!
tfboy's Avatar
Members Car: "Fake" Black Magic vRS
Thread moved to diag area
Xavier
tfboy is offline
Old 20-04-2008, 12:14   #4
Members Car:
the heating control panal lights flash on and off and the air recirculation and air con buttons turn them selfs off to coincide with the flashing
Old 20-04-2008, 12:17   #5
EddyH's Avatar
What car is it?
EddyH
EddyH is offline
Old 20-04-2008, 12:23   #6
Members Car:
skoda fabia 1.9 sdi
Old 20-04-2008, 20:18   #7
Members Car:
Has anyone else had this problem or heard of this before ?
Old 20-04-2008, 20:28   #8
Mongreller
devonutopia's Avatar
Members Car: Skoda Fabia Mongrel
Images: 5
Just an intermittent loss of comms between the car and the aircon. Nowt to worry about. If the aircon stops working, then it's worth rescanning, and seeing if it's something more serious.
devonutopia is offline
Old 20-04-2008, 21:23   #9
Members Car:
thanks for the reply ! but the aircon is not working as i mentioned ~ the heating control panal lights flash on and off and the air recirculation and air con buttons turn them selfs off to coincide with the flashing ~ therefore the air recirculation and air con are not working. i have rescanned a few times and cleared the fault but it comes back straight away.
1 Fault Found:
has anyone else come across this problem before.
Old 20-04-2008, 21:37   #10
Txt Spk Police
VRStu's Avatar
Members Car: Audi S3
I'd say it might be a broken or damaged wire on the A/C Controller.
Stu
VRStu is offline
Old 20-04-2008, 21:48   #11
Members Car:
thanks for that info i'll start to look in that direction. would you or anyone else be able to tell me specifically where to look.
Old 20-04-2008, 22:10   #12
Txt Spk Police
VRStu's Avatar
To be honest mate it's not an envious task.
What year is it?
Are you pretty handy with electrical diagnosis?
Stu
VRStu is offline
Old 20-04-2008, 22:22   #13
Members Car:
its a 2001 skoda fabia 1.9 sdi i'm no expert by any means but quite handy
Old 20-04-2008, 22:29   #14
Mongreller
Images: 5
Hmm, i would be tempted to just get a second hand replacement AC switch assembly unit complete. Should be plenty around I imagine
cars dismantled by skospares.com for all your skospares might be one place to try.
Old 20-04-2008, 22:42   #15
Txt Spk Police
VRStu's Avatar
There are two wires, CAN Hi & CAN Lo (Normally Orange/Brown & Lilac/Brown) that will go to plug XS2 on the Electical Controller under the drivers knee panel.
They would be the signal ones directly from the A/C controller.
The problem is it could also be under the bonnet to the ECU.
Stu
VRStu is offline
Old 20-04-2008, 22:55   #16
Members Car:
thanks devonutopia and VRStu for your reply's they are very helpful and i will look into both routes thanks again
Old 14-07-2008, 20:05   #17
Members Car:
Does anyone have any detailed instructions on how i could attempt to fix this problem
Old 15-07-2008, 07:28   #18
Jelly Mould
fordfan's Avatar
Members Car: Ford
It would be a case of getting a wiring diagram and tracing the wires looking for any dodgy connections. The key to the problem is finding out where the A/C controller is. I would start at the A/C panel in the car and would hope that it is a poor connection there. The CAN wires are twisted together, which will help with identification. It could even be an internal fault with a control unit.
fordfan is offline
Old 20-07-2008, 09:04   #19
Members Car:
ok thanks fordfan
Similar Threads
17 digit immobiliser code vagcom? skudmissile Diagnostics & VAG-COM 5 23-11-2007 20:23
Power steering fault - fault code 01288 - is this the normal plastic sensor fault? mgskoda Diagnostics & VAG-COM 6 05-11-2007 19:31
vagcom fault 18263 octav.ed Revo Technik 9 25-09-2007 17:49
VagCom Error Code 1704 vRS_Si Diagnostics & VAG-COM 17 30-07-2004 21:34
