40,609 Members 1,517,984 Posts
Help requested with ABS fault code
This is a discussion on Help requested with ABS fault code within the Diagnostics & VAG-COM forums, part of the General Motoring Discussions category; Hello all, I wonder whether anyone cold point me to likely sources of the attached error code. I suppose I'm ...
Old 08-08-2008, 17:55   #1
TKW
Members Car:
Hello all,
I wonder whether anyone cold point me to likely sources of the attached error code. I suppose I'm looking for loose / dirty connections?
I've seen the wiki page, and wondered, to help me trace the cable from the Hall sensor, can anyone give me an idea of it's route to the ABS controller (and where this might be?!).
At least it doesn't seem to be the controller up the Suwannee
Many thanks,
Address 03: ABS Brakes Labels: 1C0-907-37x-ESP-A.LBL
Part No: 1C0 907 379 F
Component: ESP ALLRAD MK60 0104
Coding: 0023174
Shop #: WSC 31480
1 Fault Found:
00283 - ABS Wheel Speed Sensor; Front Left (G47)
012 - Electrical Fault in Circuit
Octavia 4x4
TKW is offline
Old 08-08-2008, 18:04   #2
TKW
Members Car:
Re: Help requested with ABS fault code
Also, I don't suppose anyone can check if 1J0 927 803 is the replacement part for the front left (nearside) speed sensor? 51/Oct/4x4
Octavia 4x4
TKW is offline
Old 08-08-2008, 18:36   #3
Txt Spk Police
VRStu's Avatar
Members Car: Audi S3
Might worth making sure there isn't any dirt or debris stuck in and around the sensor and while you have the wheel off check the plug for signs of water ingress.
That number does refer to a left front sensor.
Stu
VRStu is offline
The Following User Says Thank You to VRStu For This Useful Post:
TKW (08-08-2008)
Old 08-08-2008, 23:04   #4
TKW
Members Car:
Hi Stu, thanks for checking the part No . Looks like replacing that is quite a cheap option.
I thought that dirt etc was more likely to throw the "Mechanical Malfunction" exception - I've logged wheel speeds and they show 0 for the front nearside. I'll do my best to check the connections with a scissor jack (!) tomorrow. You don't happen to know whether there are any other vulnerable connections between the wheel and the controller, do you?
Thanks again for your help,
TKW
Octavia 4x4
TKW is offline
Old 08-08-2008, 23:11   #5
Txt Spk Police
VRStu's Avatar
The loom on each side is a replacable part so that will obviously have a connection at each end.
Stu
VRStu is offline
Old 09-08-2008, 06:35   #6
Jelly Mould
fordfan's Avatar
Members Car: Ford
It'll likely be the sensor. Removing it will be a bit time consuming as they get stuck and you eventually end up destroying it. You'll be quite surprised at the amount of copper wire that they contain. GSF do sensors which are around half the price of VW ones.
fordfan is offline
The Following User Says Thank You to fordfan For This Useful Post:
TKW (10-08-2008)
Old 10-08-2008, 19:23   #7
TKW
Members Car:
I took your advice and got the GSF part on Saturday for about £17:00. I can't for the life of me get the old part out, though because, as you predicted, the unit split and I now have a large pile of "ginger hair" in the passenger footwell.
On the plus side, I connected the new sensor and now the ABS controller says that there's a mechanical error- yes, because it's nowhere near the ABS ring! That rules out loom or controller problems thank goodness. Off to a garage tomorrow with my tail between my legs, I hope that they have a bit more know-how then me and a few more tools than a pair of mole grips and an Allen key.
Thanks all,
Octavia 4x4
TKW is offline
Similar Threads
Fault code 00285 ABS brakes Adamhodg Diagnostics & VAG-COM 3 18-05-2008 07:47
Power steering fault - fault code 01288 - is this the normal plastic sensor fault? mgskoda Diagnostics & VAG-COM 6 05-11-2007 19:31
INSP light and ABS Fault JLneonhug Diagnostics & VAG-COM 5 24-10-2007 13:15
VW Polo ABS fault = MOT fail sdenny RWD Skodas and others 0 26-10-2005 17:28
ABS and wheel speed sensor fault? Fasterbaby Diagnostics & VAG-COM 4 25-01-2005 21:08
