This is a discussion on Help on these fault codes. within the Diagnostics & VAG-COM forums, part of the General Motoring Discussions category; Well a few weeks Back i went to a mates who has Vag com, He plugged my car in and ...
| Briskodian Join Date: Apr 2007
Members Car: Red 2001 octavia VRS Thanks: 1
| Help on these fault codes. Well a few weeks Back i went to a mates who has Vag com, He plugged my car in and all that came up was the N24v Has anyone else have this problem and if so how can i sort it. Anyway yesterday i had it plugged in again and it was reading the same fault again and 2 other codes appeared, These were 17608 18010 17705 which i believe is the N24. Help most appreciated ![]() |
Members Car: Audi S3 Thanks: 195
| Re: Help on these fault codes. 17608/P1200/004608 - Ross-Tech Wiki Quite common - Do a search here. 18010/P1602/005634 - Ross-Tech Wiki This one often comes up if the battery has been disconnected. 17705/P1297/004759 - Ross-Tech Wiki Another common one pretty well covered.
__________________ Stu Stu's Websites - http://www.fabia-vrs.com & http://www.octavia-vrs.com Stu's Car - 2008 Audi S3 - Ibis White, Black Optics Pack, Privacy Glass, Auto Bi Xenon Headlights, Rain Sensing Wipers, Bose Sound System, Ipod Prep, GSM Phone Prep, Flat Bottom Multi Function Steering Wheel, Electric Folding Mirrors, Acoustic Parking, Cruise Control, Interior Light Pack, Non Smokers Pack. SWMBO's Car - 2008 Seat LEON TDi Stylance, Black Magic, Sports Pack, Rear Parking Sensors. Something for Weekend - A Patio |
| Re: Help on these fault codes. Very helpful that, Glad theres people like you about or i'd be well stuck as i'm new to skodas and modern cars. The 18010 figures because i had the battery unplugged whilst fitting my stereo gear, I have heard that it messes up with the airflow or something which causes delay when putting your foot down on the pedal. have you heard this too? |
| Re: Help on these fault codes. Both of them relate to the N249V so i'm going to order one of them regardless. Heard they are pretty cheap. Gonna have a good nosey around the hoses, chech throttle body too |
| | #5 | |
| Re: Help on these fault codes. Quote:
Throttle Body Alignment (TBA) - Ross-Tech Wiki May need to call on your mate again ![]()
__________________ Stu Stu's Websites - http://www.fabia-vrs.com & http://www.octavia-vrs.com Stu's Car - 2008 Audi S3 - Ibis White, Black Optics Pack, Privacy Glass, Auto Bi Xenon Headlights, Rain Sensing Wipers, Bose Sound System, Ipod Prep, GSM Phone Prep, Flat Bottom Multi Function Steering Wheel, Electric Folding Mirrors, Acoustic Parking, Cruise Control, Interior Light Pack, Non Smokers Pack. SWMBO's Car - 2008 Seat LEON TDi Stylance, Black Magic, Sports Pack, Rear Parking Sensors. Something for Weekend - A Patio | |
| Re: Help on these fault codes. I'm no huge expert on the 1.8T but I seem to recall that if the DV has a problem, which yours does have a code, this can cause the N249 to be constantly wedged open and they can burn out, again which yours has a code for. So you may want to consider a replacment DV as well. If it is still on the original OEM one then they do fail.
| Re: Help on these fault codes. Right, would the forge DV be a better investment ![]() |
| Briskodian | Re: Help on these fault codes. Vrsdale, I'm not much of an expert on these engines, but does your car release its boost when lifting off the throttle? i.e does the diverter valve dump in one go or does it flutter at all? If its the latter you'll find the D.V knacked and so need a new one.
__________________ 06 RACE BLUE vRS 18" ZENITHS - DUAL-ZONE CLIMATE - MFD2 - MAXIDOT - PARROTT 3200 - STILL TO DO - CRUISE CONTROL. |
| Re: Help on these fault codes. IT lets all the pressure out in one boost, Doesnt flutter at all, I had a good look around the engine and checked all hoses between components, I'd say nearly every hose pushed in a little and i also shoved the pin into the turbo pipe properly as it seemed to be slightly out. My car feels better already. I've just ordered the N249 valve at £44. That will be getting fitted on friday. Then hopefully Dan will plug it back in for me on VAG COM. so we will see if the problem is solved. Thanks for the information so far very helpful of you both. |
