This is a discussion on Help with VAG Com Faults within the Diagnostics & VAG-COM forums, part of the General Motoring Discussions category; Hi all. Just taken VAG-COM out for a shareware spin to see if i can find anything wrong with the ...
| Briskodian Join Date: Apr 2006 Location: Portsmouth
Members Car: Octavia GLX 1.9 TDI Thanks: 2
| Help with VAG Com Faults Hi all. Just taken VAG-COM out for a shareware spin to see if i can find anything wrong with the car before i start out on a long drive. It's come back with the following: 17957 P1549 Boost Pressure Contr.Valve Short to Ground 16485 P0101 Mass or Volume Air Flow Circ Range/Performance These i understand and the MAF has been replaced. However, i've also got the following: 16485 P1570 Contr.Module Locked 17946 P1538 Engine Shutoff Solenoid Open/Short to Ground 18008 P1600 Power Supply (B+) Terminal 15 Low Voltage which make very little sense to me, Scanning the ABS module kicked up something about ECU Intermittant Communications, which i didn't like the look off, but cleared the fault without saving the log, stupid me. I can only think that the 3 above, plus the ABS fault could be linked to a Relay 109 failure, which i have recently replaced. Any ideas? I've cleared all the faults now, so if they return i'll at least have an idea of "just wtf is going on now?" :S Cheers! |
| Briskodian | Re: Help with VAG Com Faults Has your car had a chip tune? If the chipping company dont run vagcom after it can leave the intermitent ECU communication fault |
| | #3 | |
| Re: Help with VAG Com Faults Quote:
How do i found out if it has? | |
