This is a discussion on help with vag com within the Diagnostics & VAG-COM forums, part of the General Motoring Discussions category; Hi all, have managed to borrow vag com from a friend who hadnt yet installed it. but having tried to ...
| Briskodian Join Date: Sep 2003 Location: Scotland
Members Car: Audi A4 Quattro S-Line Thanks: 1
| Hi all, have managed to borrow vag com from a friend who hadnt yet installed it. but having tried to install it the program works, downloaded from Ross..... the cable is an ebay item i believe. when i fire everything up on the laptop and connect to the car i get a " no response from controller" message when entering "select the control module tab what have i done wrong? ![]()
__________________ Ive seen a lot of good things die and im in an over emotional way So please hand me the bottle I think im lonely now, and please give me direction I think the hurt has set in, and I don’t feel nothing |
| Light Jockey! Join Date: Jul 2006 Location: Somerset, UK
Members Car: Skoda Octavia vRS Mk1 Thanks: 2
| Re: help with vag com Have you got the drivers installed for the cable correctly? and if so have you checked and set the correct COM port in the options menu of vag-com? My ebay cable came with instructions to install a supplied driver yet won't actually work unless you allow the computer to access the internet to search for drivers .Bit pointless installing the driver supplied really but I digress! Once installed if you go into device manager with the cable plugged in and go to ports (comm and lpt) then find "usb to serial" or similar, then check the com port assigned to it. When you open up vag-com go to options, select the com port (can only be 1-4 I believe so you may have to force the usb driver to use another port if this is different in manager) and test. If all works, save and you're good to go! Matt |
| Re: help with vag com yeah i have allowed it to access the net etc and got the drivers my usb serial port is com4 but when i do the test it says not found but com 3 is finding it ok interface : found type: serial pass-through opto/iso : no ross teck design : no
__________________ Ive seen a lot of good things die and im in an over emotional way So please hand me the bottle I think im lonely now, and please give me direction I think the hurt has set in, and I don’t feel nothing Last edited by kenny; 19-10-2006 at 22:28. |
Members Car: Audi S3 Thanks: 195
| Re: help with vag com Silly question but have you got the ignition on?
__________________ Stu Stu's Websites - http://www.fabia-vrs.com & http://www.octavia-vrs.com Stu's Car - 2008 Audi S3 - Ibis White, Black Optics Pack, Privacy Glass, Auto Bi Xenon Headlights, Rain Sensing Wipers, Bose Sound System, Ipod Prep, GSM Phone Prep, Flat Bottom Multi Function Steering Wheel, Electric Folding Mirrors, Acoustic Parking, Cruise Control, Interior Light Pack, Non Smokers Pack. SWMBO's Car - 2008 Seat LEON TDi Stylance, Black Magic, Sports Pack, Rear Parking Sensors. Something for Weekend - A Patio |
| Re: help with vag com good point that Stu, I was typing quick cos my laptop battery was about to die! Also I found that once the test was complete and I'd saved the settings it wouldn't work under "select control module" until I'd done the auto scan (which fails half way due to not registered), then I could select a module to connect to fine after that. Hope this helps. Matt |
| Briskodian Join Date: Jun 2004 Location: West Yorkshire
Members Car: Audi A6 Thanks: 36
| Re: help with vag com I've been speaking to Kenny and that was one of the first things I asked as well as making sure the OBD connector is pushed on firmly. He's gonna try a few things tomorrow and let us know.
__________________ EddyH Audi A6 Avant 2.7 TDI Audi A3 2.0 TDI Sport |
| Briskodian | Re: help with vag com Which version of the software is it? Some ebay cables only work with the older version which was less USB friendly. My Ebay cable however, works with all, including the latest, versions of VAG-COM. |
| Re: help with vag com its 409 which it tells you to use wuth the cable ![]() what seller did you get yours from Goochie?
| Briskodian | Re: help with vag com ecutools i think. Does it reconise it a a ross tech item when you plug it in? |
| | #10 |
| Re: help with vag com well its been plugged into vag com at star etc before if u mean that no joy finding ecutools, will try a few things when i get home after work
__________________ Ive seen a lot of good things die and im in an over emotional way So please hand me the bottle I think im lonely now, and please give me direction I think the hurt has set in, and I don’t feel nothing Last edited by kenny; 20-10-2006 at 11:19. |
| | #11 |
| Briskodian | Re: help with vag com No. When you plug it into the USB port, windows pops up a box in the lower right corner of the screen saying "foun dnew hardware: Ross-tech interface". If it does that use the hardware wizzard to search for a drive rin the VAG-COM installation folder. |
| | #12 |
| Re: help with vag com got it working although im trying to measure block 115 for boost but it says this function requires vagcom to be registered and activated please contact the author or your distributer for an activation code does this mean i need to buy the full programe form Rosstech? ![]()
| | #13 | |
| Re: help with vag com Quote:
Has your friend got the full version? Maybe you could install it and borrow his laptop?
__________________ EddyH Audi A6 Avant 2.7 TDI Audi A3 2.0 TDI Sport Last edited by EddyH; 20-10-2006 at 19:56. | |
| | #14 |
| Re: help with vag com yip will sort it out, thanks for the suggestion, ive managed to borrow one, will try and log stuff today
