This is a discussion on HELP: Wonder if TPM sensor works or not. within the Diagnostics & VAG-COM forums, part of the General Motoring Discussions category; Last mount I got the flat tire but didn't get any warning from Tire Pressure Monitoring system. When I test ...
| Briskodian | HELP: Wonder if TPM sensor works or not. Last mount I got the flat tire but didn't get any warning from Tire Pressure Monitoring system. When I test the car with wagcom (control module 65). I am getting the message of "no response from controller". So I check the control module in sequence with "19-CAN GATEWAY- coding- long coding helper-3F-BYTE 1- Bit 7- 65 tire pressure monitoring". This was not selected (ticked) and I ticked it But after ticking it I tested the car, I got the message below in either car is working or not: "01325 - Control Module for Tire Pressure Monitoring (J502) 004 - No Signal/Communication Freeze Frame: Fault Status: 01100100 Fault Priority: 2 Fault Frequency: 1 Reset counter: 240 Mileage: 21085 km Time Indication: 0 Date: 2000.00.00 Time: 02:31:11" So I'm not sure my TPM sensor is working. I need your help on this subject How can I understand in another way if my TPM sensor is working or not? My cable Micro-Can from ROSSTECH and licenced. I'm using 704.1 ( Because I couldn't make the newer version (805. etc) worked. My car is OCT II- 2006 ELEGANCE with TPM sensor and button on dash) All replies will be apreciated. Best regards Last edited by isoma; 06-10-2008 at 00:10. |
| Briskodian Join Date: Aug 2005 Location: Back in the Green
Members Car: 2 Octavia IIs: an L&K combi and a vRS hatch. Thanks: 51
| Re: HELP: Wonder if TPM sensor works or not. I might not be on the right track here but there are different TPM systems available across the VAG platforms, the Octavia system doesn't actually see any real tyre pressure but works things out via the ABS sensors, if it sees any drastic change in the circumference of the tyre (read: puncture) it will flag up a TPM warning. The reason you have a comms error/ no response from module 65 is because it probably isn't there. It is known for not being particularly accurate, some report good results, some people say it's cr@p. I would untick the box or it will keep flagging up the same error.
__________________ MY08 L&K: Black-Estate-Diesel-Sunset Glass-MFD2-W8 Interior light-Colour coded door strips-LED sidelights and Puddle lights-VAG-COM fettled-Lovely! SWMBO's: MY08 vRS TDI - Standard ![]() |
| The Following User Says Thank You to dstev2000 For This Useful Post: | isoma (08-10-2008) |
| Partner Join Date: Sep 2003 Location: Newport Pagnell
Members Car: Mk2 Golf GTi 16v and building a 20VT MK2. Images: 2 Thanks: 29
| Re: HELP: Wonder if TPM sensor works or not. The above is correct, the TPM system on the Octavia doesnt have its own control unit, its just part of the ABS programming. |
| The Following User Says Thank You to Lummox For This Useful Post: | isoma (08-10-2008) |
| Briskodian | Re: HELP: Wonder if TPM sensor works or not. Really thanks. it is very understandable. I couldn't think of it from this point. I will untick it soon. |
| Briskodian Join Date: Apr 2006 Location: Mid Germany
Members Car: MY 2007 Thanks: 1
| Re: HELP: Wonder if TPM sensor works or not. Please contact us (Ross-Tech) directly regarding making the current version work.
__________________ Sebastian |
| TPM - retrofittable? | phiL&K | Octavia II | 1 | 27-09-2007 22:49 |
| TPM - standard or optional on new VRS? | FocusZtec | Octavia II | 8 | 09-06-2007 23:06 |
| TPM addition | cheezemonkhai | Octavia II | 19 | 12-10-2006 09:27 |
| Tpm | darnell | Octavia II | 5 | 24-06-2006 07:55 |
