This is a discussion on How to change ECU map on VAGCOM? within the Diagnostics & VAG-COM forums, part of the General Motoring Discussions category; Hi, My car is remapped and if I want to return it to stock. How can I do that using ...
| Briskodian | How to change ECU map on VAGCOM? Hi, My car is remapped and if I want to return it to stock. How can I do that using VAGCOM? Does anyone know? I've heard of changing softcoding from 1 to 0 or similar depending on the location of the map. But where in VAGCOM do I do this? |
| Briskodian | Re: How to change ECU map on VAGCOM? I would be interested to know if this is possible. I want a switchable remap, but I am loathed to pay £200 more for it. I'm guess depending on the remapper this would be possible, after all I think one of the remappers use the diagnostic port to swap maps. |
Members Car: '97R BMW 328i Saloon Thanks: 728
| Re: How to change ECU map on VAGCOM? ![]() I really don't think its something this easy. The switchable maps I know of work by reuploading the different map each time from a standalone device. I'm sure the tuner who did your mapping will happily return it to stock for you. ![]()
| Briskodian | Re: How to change ECU map on VAGCOM? Like tom says its not possible to do via vagcom unless you already have a switchable map of somekind already loaded.
__________________ Run out of CASH |
Members Car: Audi S3 Thanks: 195
| Re: How to change ECU map on VAGCOM? I think Custom Code was switchable using VAG-COM and REVO used have use Lemmiwinks software although it wasn't an on/off switch.
__________________ Stu Stu's Websites - http://www.fabia-vrs.com & http://www.octavia-vrs.com Stu's Car - 2008 Audi S3 - Ibis White, Black Optics Pack, Privacy Glass, Auto Bi Xenon Headlights, Rain Sensing Wipers, Bose Sound System, Ipod Prep, GSM Phone Prep, Flat Bottom Multi Function Steering Wheel, Electric Folding Mirrors, Acoustic Parking, Cruise Control, Interior Light Pack, Non Smokers Pack. SWMBO's Car - 2008 Seat LEON TDi Stylance, Black Magic, Sports Pack, Rear Parking Sensors. Something for Weekend - A Patio |
| Hardcore Join Date: Feb 2006 Location: Bahrain
Members Car: Fabia vRS Thanks: 209
| Re: How to change ECU map on VAGCOM? Don't quote me on this - but IF you have a switchable map you should see a soft coding number on the engine module login screen thingie, second or third from top on the left IIRC. Usually it starts with 0 for the standard map and is changed to 1 for the next map - you use the 'recode' function. HTH Bas
__________________ Fab vRS - Black Magic - PD160 intake - Forge FMIC - colour coded front grille -SLC Splitter - K&N Airfilter -SEAT Strutbrace - Jabba ARB - IC Waterspray (need to wire it in!) - 312mm TT brakes - Eibach Springs - Skoda Reversing sensors - Devonutopia Tuning (tm) Custom Exhaust (2 1/4" straight pipe) - Short shifter mod- 5 brake light mod - Helix Steel SMF + Organic Clutch + pressure plate - Peloquin LSD - TD stage 2 Hybrid - Washbrook remapped ECU - Uprated injectors - Cupra bushes -Poly-filled dogbone - Allard racepipe - Pirelli Dragons - Forge Rear Strutbrace - DIY SS upper boostpipe delete -Koni FSD's - elephant pipe CCV mod |
| | #7 | |
| Briskodian | Re: How to change ECU map on VAGCOM? Quote:
| Hey thanks!! You can send it on care of Xav or WW please....... Btw - soon for sale an ECU with 3 switcheable maps on it - OEM, pro tuned to 187.5bhp - no FMIC and even higher-tuned for a FMIC. ![]()
| Briskodian | Re: How to change ECU map on VAGCOM? Just tried it. Controller 01 - Engine, softcoding was a 5 digit number starting 11500. Guessing it cant be changed. The only reason I asked is that CustomCode ones can be changed like so. Oh well, will take it to mapper when it needs to go into stock mode. |
| | #10 |
| Briskodian | Re: How to change ECU map on VAGCOM? If your softcoding states 11500, couldn't you change it back to 01500? Would this put it back to standard? |
| | #11 |
| Briskodian | Re: How to change ECU map on VAGCOM? No, I couldn't change it. I've even tried 01500 ![]() |
| ECU Re map? advice please | Bcollb | Superb | 2 | 23-08-2007 18:00 |
| Vagcom and Passat - what can I change!? | Tom_vRS | Diagnostics & VAG-COM | 10 | 30-03-2007 08:21 |
| Switchable ECU un-map - Detectable or not? | JMC | Fabia I | 23 | 27-03-2007 01:18 |
| Is it worth combining a water pump change with a cambelt change? | DGW | Octavia I | 34 | 20-09-2006 19:16 |
