This is a discussion on HVAC Coding - Octavia II within the Diagnostics & VAG-COM forums, part of the General Motoring Discussions category; Does anybody know if it is posible to change the coding of the HVAC module on an Octavia II? Whenever ...
| Briskodian | HVAC Coding - Octavia II Does anybody know if it is posible to change the coding of the HVAC module on an Octavia II? Whenever I remove the key from the ignition the HVAC reverts to "dual" mode off. Thus, the passenger has to reset the temperature on their side of the car, once the car is restarted. This is annoying if undertaking several short trips. In my Golf the temperatures come back to the settings they were left at, in the Skoda the passenger's side changes to the same as the driver's side - is it possible to change this? I have looked with VCDS, but the coding boxes aren't selectable for the HVAC module. Is there a login code to do this? |
| Briskodian | Re: HVAC Coding - Octavia II Understood, thanks for the reply. Is it possible that this setting is in another module somewhere, or is it hardcoded into the EEPROM / flash of the HVAC module? The only reason I ask is that other owners have told me that theirs does not behave the same way. That is, when they turn off the ignition their passenger side temperature stays independant of the driver's side (this is also how my Golf GTI behaves). |
| Briskodian Join Date: Apr 2007 Location: Finland
Members Car: Skoda OCtavia II Combi Elegance 1.6FSI Thanks: 22
| Re: HVAC Coding - Octavia II I have one question about the basic setting of HVAC module. Is there a special procedure to make this? I've enabled the basic setting and the module runs the flaps through their positions. The climatronic screen show some odd signs. Do you need to do something else or is that it? My problem is the famous climatronic flapping sound which should be cured with dealer diagnostics easily. Is the basic setting the same thing?
__________________ '05 OctaviaII 1.6FSI Combi Elegance : Xenons, Aftermarket H1 HID kit on main beams, Rain sensor, Autodimming rearview mirror, Light assist, Dual-Zone Climatronic, MFD2, Kufatec Digital music interface (USB, SD), MaxiDot (Retrofitted, parts from VrStu), Multi-function steering wheel (Retrofitted, parts from VrStu), Rear Parking Sensors. |
| Briskodian Join Date: Apr 2006 Location: Mid Germany
Members Car: MY 2007 Thanks: 1
| Re: HVAC Coding - Octavia II Nope, nothing special besides the basic setting. Your noise problem is known, there is a software update like thing available but that doesn't fix it in all cases. At the end your dealer should know what to do about this (I think it was replacing the module and/or the related flap).
__________________ Sebastian |
| The Following User Says Thank You to Theresias For This Useful Post: | downtime (10-10-2008) |
| | #6 | |
| Re: HVAC Coding - Octavia II Quote:
__________________ '05 OctaviaII 1.6FSI Combi Elegance : Xenons, Aftermarket H1 HID kit on main beams, Rain sensor, Autodimming rearview mirror, Light assist, Dual-Zone Climatronic, MFD2, Kufatec Digital music interface (USB, SD), MaxiDot (Retrofitted, parts from VrStu), Multi-function steering wheel (Retrofitted, parts from VrStu), Rear Parking Sensors. | |
| | #7 | |
Members Car: Octavia II vRS Thanks: 31
__________________ GAFF ![]() Briskoda Ireland Events, Meets & Pictures.....Race Blue Octavia MkII vRS.....Old Octavia MkI vRS | |
| The Following User Says Thank You to GAFF For This Useful Post: | downtime (10-10-2008) |
| Colour Coding? | Gez | Fabia I | 13 | 15-09-2008 06:24 |
| Octavia II controller coding help | Aulis | Octavia II | 3 | 13-05-2008 14:53 |
| Octavia I instrument cluster coding | AJB | Diagnostics & VAG-COM | 5 | 05-03-2008 13:39 |
| Log-ins/ Coding for Octavia I vRS HVAC | enigmaci | Diagnostics & VAG-COM | 7 | 13-08-2007 15:42 |
| C coding | SkodiRS | The Roadside Hotel | 7 | 20-04-2006 08:54 |
