40,613 Members 1,518,164 Posts
Im having trouble adapting an ECU to my dashpod..
This is a discussion on Im having trouble adapting an ECU to my dashpod.. within the Diagnostics & VAG-COM forums, part of the General Motoring Discussions category; I'm trying to fit another ECU to my car, and having followed the procedure to the letter for doing so ...
Old 12-07-2008, 13:11   #1
Ex Modder
Shifty's Avatar
Members Car: Omega 2.5 V6 CDX Auto
Images: 2
I'm trying to fit another ECU to my car, and having followed the procedure to the letter for doing so with VAG COM many many many times taking up many many hours so far of fiddling about, I'm not getting anywhere.
Procedure is as follows:-
Login to the ecu with the 4 digit pin
Select adaptation - channel 50 - read
Enter Pin for old ECU
Test
All goes well up to this point - whereby I should have the save button enabled. The save button does not enable.
I have a fully registered paid for genuine Vag Com version 311.2 and a usb fleaybay cable.
I've tested the functionality of Vag Com quite extensively now, and it all works brill, apart from this enabling of the save button to "pair" my ECU to the car.
Would anyone have any ideas why this could be happening and any possible solutions?
TIA
<----- Add me on Xfire.
Everyone knows someone called Dave. That's me - I'm Dave™
Shifty is offline
Old 12-07-2008, 13:37   #2
Briskoda Staff
auroan's Avatar
Re: Im having trouble adapting an ECU to my dashpod..
Do you know someone local that has a ross-tech cable and the lastest software (just incase it's that)
The Audi Fleet;
'05 Audi A4 2.0 Tdi SE - interior light pack, 3 spoke mfsw, 30mm drop, front seat nets (back), fiscon BT handsfree.
'96 Audi A4 2.6 Avant (Breaking - Check out http://shop.ebay.co.uk/merchant/auroan)
'93 Audi 80 Avant - Charlie the labrador transporter.
auroan is offline
Old 12-07-2008, 14:06   #3
RADIOTWO's Avatar
Members Car: Fabia
Hi Shifty
The latest version is 805, so a bit of catching up to do !
Radiotwo
RADIOTWO is offline
Old 12-07-2008, 14:15   #4
bearthebruce's Avatar
Members Car: 2006 Audi A4
I agree with radiotwo and auroan. Try to find someone with a genuine RT interface cable and the latest software. By the way, what year and model car is this?
To be clear, I am not trying to find fault with the fleabay cable or version 311.2. It just seems to me that a 5 year old version of the software may be having issues with your car, especially if it is newer than '03.
-Bruce-
Ross-Tech, LLC
bruce@Ross-Tech.com
bearthebruce is offline
Old 12-07-2008, 14:30   #5
Hardcore
Basil's Avatar
Members Car: Fabia vRS
same prob reported here with fix: Fourtitude Forums: Having trouble adapting a new ECM/ Have SKC Immo III
HTH
Bas
Fab vRS - Black Magic - PD160 intake - Forge FMIC - colour coded front grille -SLC Splitter - K&N Airfilter -SEAT Strutbrace - Jabba ARB - IC Waterspray (need to wire it in!) - 312mm TT brakes - Eibach Springs - Skoda Reversing sensors - Devonutopia Tuning (tm) Custom Exhaust (2 1/4" straight pipe) - Short shifter mod- 5 brake light mod - Helix Steel SMF + Organic Clutch + pressure plate - Peloquin LSD - TD stage 2 Hybrid - Washbrook remapped ECU - Uprated injectors - Cupra bushes -Poly-filled dogbone - Allard racepipe - Pirelli Dragons - Forge Rear Strutbrace - DIY SS upper boostpipe delete -Koni FSD's - elephant pipe CCV mod
Basil is offline
Old 12-07-2008, 14:43   #6
roo
Ding, dong
roo's Avatar
Images: 4
Originally Posted by RADIOTWO View Post
Hi Shifty
Radiotwo
The Ebay interface and v311.2 of Vag com work perfectly well if you have a mk1 Fabia as every vesion afterwards is essentially upgrades and adaptions so that you need the intelligent ross-tech dongle and support for CAN-BUS cars (MK5 golf onwards), which if you don't need, it's not worth having. Even the latest version of VCDS (as it's now known) has more or less the same functionality as 311.2 when used on a mk1 fabia (or mk1 octavia and superb for that matter)
Dave, IIRC VAG added extra security to the ECU coding so that without a valid dealer log in you are unable to do certain things with the car. I'd guess that you'd need to speak to a friendly dealer and slip them a few quid, or if possible, get their supplier number to log into vag com (As you hav not mentioned that you have already done this).
Ross-Tech: VAG-COM: Immobilizer 3 Instrument Cluster Swapping
*EDIT* Just read Basils post and thread, looks like that may work too.
Jeff: Ambitious, but rubbish
Originally Posted by topgear.com
The police use the Octavia Vrs because they don’t look fast enough to catch a cold. That’s cheating
roo is offline
Old 12-07-2008, 14:54   #7
Mongreller
devonutopia's Avatar
Members Car: Skoda Fabia Mongrel
Images: 5
Hmm, so sounds like you just need to have over 12v...
devonutopia is offline
Old 12-07-2008, 16:38   #8
Ex Modder
Shifty's Avatar
Images: 2
Thanks for all the replys guys. Sorted it having read Bas's link. Love you Bas!! Thanks mate.
All it was I needed to d/l the latest 311.2 version off ross tech site. Worked first time.
Oh, and the map it's running now is INFINATELY better than the one I had on before.
Shifty is offline
Old 12-07-2008, 16:59   #9
Mongreller
Images: 5
Good to hear you got it sorted mate.
Should be getting mine mapped fairly soon again. Need to get my exams out the way first though, and get the water/meth kit on too.
Get it RR'd asap mate. Be interested to know if your torque curve has been smoothed out, and peaks higher up, as it should do with a derv running big turbo.
Old 12-07-2008, 17:05   #10
Hardcore
Basil's Avatar
Smile Re: Im having trouble adapting an ECU to my dashpod..
Just glad to hear you're happy mate.....
Basil is offline
Similar Threads
ECU coding to dashpod Shifty Maintenance & Performance 6 05-07-2008 09:38
Problem adapting keys to immob TKW Diagnostics & VAG-COM 7 13-03-2008 18:25
Is it easy to split the dashpod? devonutopia Fabia I 6 18-03-2006 13:47
