40,613 Members 1,518,156 Posts
Interested in Learning how to Remap ECU
This is a discussion on Interested in Learning how to Remap ECU within the Diagnostics & VAG-COM forums, part of the General Motoring Discussions category; Hi, Are there any members, like me, that would be interested in learning how to remap/ flash an ecu. Perhaps ...
Old 05-12-2005, 18:00   #1
Members Car:
Hi,
Perhaps the start is an understanding of vag-com.
I would appreciate your ideas!
Best wishes
John
johnyardley is offline
Old 05-12-2005, 18:04   #2
splash!!!!
bengie's Avatar
Members Car: 4x4 turbo estate
Re: Interested in Learning how to Remap ECU
it would be nice but i doubt we would have the time involved to leant as it must be a prettyinvolved thing. but it would be very cool to be able to do it yourself
owner of a skoda octavia 4xvrs3
bengie is offline
Old 05-12-2005, 22:38   #3
Members Car:
Maybe a look here will help/put you off!
http://www.andywhittaker.com/
Chris_55 is offline
Old 05-12-2005, 22:40   #4
ScoobyChris's Avatar
Members Car: Fiat Panda
I'd love to, but I suspect that I don't have the necessary skills (car or computer!) to do it. If you manage to find any more out, count me in
VAG-COM is relatively trivial in comparison and is a specific tool for interrogating/changing codings on the ECU. It cannot be used to rewrite/reflash an ECU
An online demo of VAG-COM can be found on the Ross-tech site
Chris
ScoobyChris is offline
Old 06-12-2005, 10:51   #5
Members Car:
Hi,
Initially it looks very technical, but I wondered if there is a software package that would make the process more user friendly.
Chris 55 took a look at your page - it looks very technical I agree. Have you seen this tool:
http://www.elecauto.com/logicaldevices.htm
Also, I know a little about hardware/ software as iam an IT teacher at 6th form college.
I appreciate your posts.
John
Old 06-12-2005, 10:58   #6
EddyH's Avatar
Members Car: Audi A6
There are tools out there for remapping cars. They allow parameters to be tweaked such as boost, fueling timing.
Simple versions of these are lemmiwinks, Custom-Settings and APR V-Tune, however these only allow global changes. More advanced versions which allow tweaking throughout the entire tables are available from the likes of Dimsport but are very expensive and only viable if you are able to sell alot of remaps.
EddyH
Audi A6 Avant 2.7 TDI
Audi A3 2.0 TDI Sport
EddyH is offline
Old 06-12-2005, 11:10   #7
Members Car:
Eddy,
Thanks for the post.
Anny experience of the 'limited parameter' tools. Do you know which parameters you can adjust.
Have you got any links?
Best wishes
John
Old 06-12-2005, 11:23   #8
faboka vrs's Avatar
Here's a link to Lemmiwinks by badger 5 http://www.seatcupra.net/forums/showthread.php?t=45369
And one for APR V-Tune
http://www.seatcupra.net/forums/show...ght=apr+v-tune
I too would also be interested in any info.
John
His
Slow Black Diesel Powered Hatchback
Hers
Full Fat HotHatch with Cup suspension and spolier kit
faboka vrs is offline
Old 06-12-2005, 11:28   #9
EddyH's Avatar
You can only use APR V-Tune if you have APR software and the V-Tune tweaking is enabled. AFAIK lemmiwinks is no longer available (although I have a copy). Custom-Settings is available on the Custom-Code website.
On a standard car you can adjust timing up or down, boost can only be adjusted down (unless you have a CC remap), there's also a few other things. If you download the software there are pop-up explanations if you hover the cursor over each of the options.
EDIT: Looks like Bill has made lemmiwinks available on his site.
EddyH
EddyH is offline
Old 06-12-2005, 11:31   #10
EddyH's Avatar
Just to add you WILL need vagcom along with any of these tools to enable you to log the changes and ensure the engine is running safely and if there has been an improvement.
EddyH
EddyH is offline
Old 06-12-2005, 11:33   #11
EddyH's Avatar
This is what Dimsport offer which I believe is what Jabba use: http://www.dimsport.com/prodotti/chiptuning.aspx
EddyH
EddyH is offline
Old 06-12-2005, 11:34   #12
faboka vrs's Avatar
Agree. didn't Revo have a good guide about sps and checking the changes with vag-com?
Anyone tried lemmiwink or cc on a diesel yet to see if it works?
John
His
Hers
Old 06-12-2005, 19:31   #13
Members Car:
Thanks above contributors!
I assume that these tools are suitable for diesel and petrol turbo cars.
Firstly, I would like to upload some standard and modified maps to compare.
Would the tools be capable of uploading from ECU?
There are a number of Fabia VRS owners that have modified maps by jabba etc I would likew to study. The progree on to my own car where a non standard turbo or injectors have been added.
Reasonable plan?
John
Old 06-12-2005, 19:34   #14
Members Car:
Latly , it looks as though dimsport offer training in ecu mapping.
Anyone heard of uk companies offering this?
John
Old 08-12-2005, 09:48   #15
Txt Spk Police
VRStu's Avatar
Members Car: Audi S3
I have done a fair bit of research on this. It's not something to be taken lightly.
I do have the schematics of a device that will enable you to reprogram your ECU but you would have to be pretty savvy with electronics to build it. To buy a ready made device would cost circa 1 - 2 thousand pounds although some cheaper can be found by searching German ebay.
Stu
VRStu is offline
Old 08-12-2005, 11:41   #16
Members Car:
Hi,
Iam not an electronics expert. perhaps BryanD might be interested in taking a look at the schematics will he returns from his Dutch trip.
VRS Stu and others - I wondered if a group could form to buy a second hand device off ebay germany. Have you got an idea of the approximate price they auction for, or, have you links to items being offered for auction on ebay currently.
Best wishes
John
Old 08-12-2005, 11:48   #17
EddyH's Avatar
Why buy old technology? Most current remaps are done using a serial cable and laptop. It's similar to a vagcom cable but wired differently. I suspect the device you are referring to is some sort of EPROM burning device and will also involve desoldering and soldering to change and doing this too many times is likely to kill your ECU.
EddyH
EddyH is offline
Old 08-12-2005, 11:49   #18
Txt Spk Police
VRStu's Avatar
John
Don't take this the worng way, I'm not wishing to put you down or belittle your capabilities but perhaps some things are best left to those that know what they are doing. Custom mappers are highly skilled guys. You could do a lot of damage to your car.
If you just want to map a few cars a make a few ££ then you can buy the kit generic maps from Red Dot Racing resellers.
Stu
VRStu is offline
Old 08-12-2005, 11:51   #19
Txt Spk Police
VRStu's Avatar
The device I am referring to is an OBD device.
Stu
VRStu is offline
Old 08-12-2005, 11:55   #20
Txt Spk Police
VRStu's Avatar
http://www.speed-buster.de/en/flashbooster.html
http://translate.google.com/translat...l%3Den%26lr%3D
Stu
VRStu is offline
Old 08-12-2005, 11:57   #21
EddyH's Avatar
All remaps I've seen are done with a cable and laptop. There's no big box of tricks.
EddyH
EddyH is offline
Old 08-12-2005, 12:06   #22
Txt Spk Police
VRStu's Avatar
You still need an interface Eddy. It's not a big box of tricks simply a communications device.
Stu
VRStu is offline
Old 08-12-2005, 12:12   #23
EddyH's Avatar
That costs £1-2k
Revo and Custom-Code don't use anything near as complex, their cables are very similar to a vagcom cable.
EddyH
EddyH is offline
Old 08-12-2005, 12:23   #24
Txt Spk Police
VRStu's Avatar
The VAG-COM cable still uses an interface - It's normally built into the OBD plug.
So what equipment and software can you recommend for the job?
Stu
VRStu is offline
Old 08-12-2005, 12:26   #25
EddyH's Avatar
I know the interface is built into the plug but it's alot smaller than what you linked to and certainly doesn't cost £1-2k just for the cable.
From what I've seen of your link it uses generic maps if you want to write custom maps you need software specifically for that such as dimpsort or one of the many others out there. However as you have said if you don't know what you're doing then it's not a good idea taking it on. I also expect a licence for the software is gonna be very expensive.
EddyH
EddyH is offline
