This is a discussion on K Line within the Diagnostics & VAG-COM forums, part of the General Motoring Discussions category; Not sure if this is in the right place but ... Can anyone explain to me how the K-Line works ...
| Briskodian | K Line Not sure if this is in the right place but ... Can anyone explain to me how the K-Line works between the ECU and sensors? Is it just a case of fluctuating the voltage according to values, or is it encoded data? If it is just fluctuating voltage is it a single wire pulsing solution of a pair etc etc? Many thanks
| Briskodian | Re: K Line 'k' line does not work between the ECU and sensors, it is (for VAG) purely a single wire line for serial communication between the various ECU's and a diagnostic scan tool. |
| Briskodian | Re: K Line The diagram I have gives the impression it was a k-line going between a sensor and the ECU. Can I take it that the K line is a serially encoded data format then, and that I would need to know the message formats, and data encoding (eg 10/8) to write to it. If it isn't a K line going to the sensor, what would it be just a simple voltage feedback?
| | #4 | |
| Briskodian | Re: K Line Quote:
It may be, but other formats like PCM or variable freqency are used it depends which sensor you mean. | |
| Briskodian | Re: K Line DPF pressure sensor (G450 on the superb) This is the start of a long line of working things out
