This is a discussion on lambda sensor help required! within the Diagnostics & VAG-COM forums, part of the General Motoring Discussions category; Hello, I need a lambda sensor, and I need to know whether I have 2,3 or 4 wires. Its a ...
| Briskodian | lambda sensor help required! Hello, I need a lambda sensor, and I need to know whether I have 2,3 or 4 wires. Its a Fabia 1.4 16V on a 2001 51 plate. Its all too confusing for me! Does anyone know this? Thanks in advance! |
Members Car: Fabia 2.0/Felicia Thanks: 53
| Re: lambda sensor help required! 4 hth ![]() |
| Briskodian | Re: lambda sensor help required! Great stuff! You are much more knowledgeable than I (can you come and fit it now?) Bit fed up, as was just going to put it up for sale, and then the dreaded light comes on...I presume there is only one of these sensors? Oh and dont laugh, but can you give me blow by blow account of where it is? Speak as if you were explaining this to somebody from outer space please .... Last edited by yorkshirepuddin; 07-04-2007 at 18:25. |
| Briskodian | Re: lambda sensor help required! Oh NO! How do I know which one it is? |
| Briskodian | Re: lambda sensor help required! THanks for this help! I had the fault read at the skoda garage, and they told me it was this sensor. The printout they gave me is unfortunately at work in my drawer, and I cant get it till a week Monday when school re-opens. I think it was 17604 |
| | #8 | |
| Jelly Mould | Re: lambda sensor help required! Quote:
| Partner Join Date: Sep 2003 Location: Newport Pagnell
Members Car: Mk2 Golf GTi 16v and building a 20VT MK2. Images: 2 Thanks: 29
| Re: lambda sensor help required! Pretty sure the first lambda probe on the 1.4 16V is a broadband lambda probe and thus a five wire probe. |
| | #10 |
| Briskodian | Re: lambda sensor help required! Oh no 4 or 5, 4 or 5, 4 or 5....? Will I be able to get someone to take it out, look and put it back before I get the replacement part? |
| | #11 |
| Re: lambda sensor help required! Dont need to remove it to see how many wires are on it. Something wrong with buying one from Skoda? |
| | #12 |
| Briskodian | Re: lambda sensor help required! Hi, No nothing wrong except I can get one online for £20. And they want to know whether its 2 3 4 or 5 wire. Is it easy to find? I really appreciate the help, THanks Janet |
| | #13 |
| Re: lambda sensor help required! Just look on the exhaust system. |
| | #14 |
| Briskodian | Re: lambda sensor help required! Thanks! I will go take a look see what I can see.. Will check back in when I have something to report! Janet |
